Where to put my receiver in Zagi 480 Si
Hello,
I was wundering if anyone of you could help me out with placing my receiver in the zagi.
I don't know where i have the place to put the receiver.
Pls help!
thx anyway
ps: srry for the bad english i'm from Belgium and i speak dutch :s
Pls help!
thx anyway
RE: Where to put my receiver in Zagi 480 Si
Nice looking Zagi!
I learned the hard way to put the receiver off to one side buried in the foam itself. If you look at the picture, you might be able to just see the different colored section inside the blue circle. My Hitec 555 receiver is buried there under the foam with a foam plug on top. The servo leads are under the edge of the motor tray lip. Being under the lip allows them to have clearance for the wires.
With the receiver in the foam like this, it is very well protected!
You're Zagi seems nice to
thx for the photo i think i shall put itt there to.
Seems like it's very protected
greetz
thx very much
if somebody has other sugestions pls post it.
Al that i know can help me
thx
greetz
thx very much
thx
Hey,
If i put my receiver there will it fly steady?
will it be in balance?
or did you put extra weight in it on the other site?
thx ahead
greetz
thx ahead
greetz
I never bothered with lateral (side to side) balance with any flying wing I have built. After I learned that putting the rx inside the battery tray will destroy the rx during a crash, I have always put the rx off to the side like that. You want the battery pack to eject out of the front during a crash and you want NOTHING between it and the path it will take on the way out! I think the rx is close enough to the centerline that it really wont make that much difference. I even have the antenna routed thru the wing and trailing off the end on that same side.
The Zagi remains fully combat ready and a blast to slope soar with.
This is my second Zagi 400X and the pictures are of it after rebuilding and covering it.
I have also built and flown the Trick RC Razor and a Wedgie. I dont think either are being made anymore. All had the rx off to the side like that.
The only place safer for the rx is on the shelf in your shop.
