Help Requested >
Help Requested
Help Requested
Old 10-03-2002 | 12:27 PM
TessPC's Avatar
Default Help Requested
Looking for the CG and Rates setup for a SIG Something Extra.
I have the ARF but think its the same as the Kit.
Old 10-03-2002 | 01:48 PM
rvd
The arf vs the kit shouldn't be that different if any at all. To be safe set the cg at 1/4 forward of the arf's recommended cg and the throws adjust them the same. You'll be fine with that.
After you fly it move the cg back a little at a time.
Old 10-03-2002 | 06:45 PM
READING FROM THE INSTRUCTION BOOK;
c/g; center of wing spar,or 3.5" from leading edge
elev;low rate,1.25", high rate 2"
ail; low rate,1", high rate 2"
rudder;low rate,1-7/8",high rate;2.25"
throttle; full range of travel.
Have a goodun,John.
