4 Star 40 engine size?
My Feedback: (20)
I'm in the process of building a 4* 40. Not sure which size engine to go with. Should I go the max and use something like Thunder Tiger 46 Pro or is this to much motor for this plane. Another engine that came to mind was a Thunder Tiger GP 42. I really think a LA 40 wouldnt be enough, but I may be wrong. So I was just wondering what would be the best engine choice for the 4 star 40. Thanks, JT
FL
This plane flies fine with a OS.40 la. Use the bigger motor if you want to but it is not needed. Extra power is always a good thing.
I have an OS .52 4stroke in mine and it has plenty of power.
The 4* is a very light plane.
The Os LA has bushings and is a rattle trap. For the small differenence in price the 46 pro is much better. I built this combo for my son and it was excellent. Flew great for 1 1/2 flights then the he had a freak midair. I keep telling myself I wanted to build another anyway.
I have two 4* 40s one has a Mag 61 4st the other has a OS 52 4st . The one with the mag has probaly 200 plus flights The OS 52 has 4 flights they are both very good but not unlimited vertical . Here they are together one bashed to PT 19 the other an Extra.
My Feedback: (7)
MO
I've run an LA .40........TT.42GP.......and a Webra .40 on mine........can't see where any more power is needed.......
A friend has one with an old OS .40 4 stroke on it.....flies great.......but the vertical ain't great........
the LA .40 did fine.......as did the GP .42........both ran great for me......and they are both light engines........
Between the 2.......I would go with the GP .42......seems like a much better engine......and a little more power than the LA..........
