giant stinger 2 piece wing
My Feedback: (8)
IL
RE: giant stinger 2 piece wing
i made root ribs with socket holes, then bored the holes in the foam with the alu. tube. then i cut the foam out in front of the dihedral brace and put tri stock between the socket and spars. next i glued the brace on with epoxy and when dry glued the foam pieces back on. i forgot about the wing hold down dowels in front. guess i will put the dowels in the fuse ply and make shallow holes in the wing dihedral brace which has been sawn into in the middle. more later. wally
My Feedback: (18)
LA
Do you plan on only using the dowels and hold down bolt to keep the 2 wing halves together, or are you planning on including a hardpoint on the wing to tighten a security bolt into the wing tube to hold the 2 halves together?
