astro-hog has wing warp
PA
The left side of my wing from the left edge of the left aileron to the tip has some warping in it, that causes the plane to roll to the right.
I need some suggestions on how to fix this?
My Feedback: (9)
CA
Need more info.. What kind of covering is on the plane? If it has iron on covering you can probably use a heat gun or iron
to heat the covering and twist the wing a little at a time to bring it back into spec. Let it cool and recheck and if needed do it again.
Sam
Sam
