GP Adjustable Engine Mount >
Old 12-18-2002 | 03:13 AM
Default GP Adjustable Engine Mount
Is that thing reliable ? It comes with the kit but I feel the split design does not really guarantee the proper alignement of each side. Especially with all the vibration around that area.
I used a DB engine mount sized for my engine in my first plane and it seems more reliable...
Anyone had a bad experience with the GP adjustable engine mount ?
Philippe
Old 12-18-2002 | 03:55 AM
My Feedback: (23)
Phil,
I have used them in a number of planes. In fact my latest plane came with no motor mount and I went and bought one.
Dave
Old 12-18-2002 | 04:22 AM
I'm running a .70 Surpass in the .40-.70 size mount.
No problems.
Old 12-18-2002 | 04:46 AM
Live Wire's Avatar
Use allen hed bolts to mount motor mounts. The sloted head bolts seem to work loose.
Old 12-18-2002 | 01:09 PM
I have used it several times on GP kits that came with it, no problems.
Vince
Old 12-18-2002 | 02:22 PM
use it all the time ,great mount,never had a problem.
Old 12-18-2002 | 02:54 PM
Although I had my doubts about adjustable mounts this is a fine design that works well. As RC Outlaw suggested, I always use DuBro socket head cap screws to attach engines to the mount and the mount to the firewall.
Dave Segal
Old 12-18-2002 | 03:13 PM
RCaeroguy's Avatar
Used it in all of my SPADs and currently in my balsa trainer.
Works great! No problems.
Old 12-18-2002 | 04:07 PM
MinnFlyer's Avatar
Ditto
Old 12-18-2002 | 10:15 PM
Feel better about it already. Will use it.
Tks.
P.
Old 12-24-2002 | 05:22 AM
David Cutler's Avatar
Good engine mount .. two points:-
1/ I glue mine together with CA after the alignment etc has been done.
2/ Make sure there's a large washer under the bolt that bolts it to the firewall, as tightening it without one can tend to push the bolt head through the oval hole.
Otherwise OK
David C.
