Rustolem is it fuelproof >
Old 02-10-2003 | 02:31 AM
Default Rustolem is it fuelproof
Hey , I'm building a TF p51. I have some old ,really old, ABS exhaust stacks that look great. I drilled the outlets out and want to paint them Silver to match the cowl. Will Rustolem hold up to glow fuel. Also how about testors brush on paint? Anyone know?Thanks..
Cuda
Old 02-10-2003 | 02:18 PM
According to a response to a letter in the March issue of Model Airplane News Rustoleum is OK for glow-powered planes.
Dave Segal
Old 02-10-2003 | 03:51 PM
Some Rustoleum is fuelproof. Others, including silver may not be. This has been discussed a number of times and the answer is usually "buy some of the color you want and test it!" If it works to your satisfaction--spray it and be happy. If not--use it for spraying lawn furniture and report the results. Regards.
Old 02-10-2003 | 04:46 PM
My Feedback: (33)
Default FUELPROOF PAINT
I have used just about every color of rustolem paint and have found that all the "GLOSS" is fuel proof and I haven't found any of there other colors that were fuel proof. Both brush and spray. You can always just clear coat it.
BH
Old 02-10-2003 | 05:42 PM
G.F. Reid's Avatar
I've found that the flats, clear and metallics don't hold up well at all to glow fuel. All of the gloss solids that I've tried held up well.
I have read somewhere that the brush on Rustoleum silver is fuelproof but I haven't tried it myself.
Incidentally, I've found that even the fuel resistant Rustoleums benefit a great deal from a good, long drying time in warm, dry weather. Otherwise, you may have problems.
Old 02-10-2003 | 07:14 PM
tpstorey's Avatar
Silver did not hold up for me.
Old 02-10-2003 | 07:42 PM
stuk_at_work's Avatar
My Feedback: (111)
Default Rustoleum Epoxy
I did my flight box in Rustoleum Epoxy paint (beige). Definately not fuelproof!
Old 02-10-2003 | 11:21 PM
Thanks all. Will test it and see.
Bye
Cuda
Old 02-10-2003 | 11:48 PM
FLYBOY's Avatar
I think you will find silver in almost anything is not fuel proof. There is something about the pigment in it. I don't know what it is but most silvers I have used came off. You see it on cars too. The only one I have ever had work was K & B epoxy paint. That stuff was great.
Old 02-10-2003 | 11:54 PM
FlyingPilgrim's Avatar
My Feedback: (26)
Cuda, make sure to dry it for a couple weeks. I tested some gloss black for use on a boat, and after it dried for a couple days I tested it. It bubbled up badly. Supposedly, if it cures a long, long long time, it will be ok.
