Converting to bolt on? >
Old 02-12-2003 | 03:55 PM
Default Converting to bolt on?
Hi guys I'm just starting to build a Hobby Lobby Telemaster 40 and I'm going to change it to a bolt on wing! Anybody out there done this? What is your preferred method?
Floater.
Old 02-13-2003 | 12:15 AM
I've converted a few planes to bolt on. What I did was drill two 1/4 inch holes in the leading edge about 1.5 or 2 inches either side of center depending on how wide the fuse is. Glue 1/4 dowels so that they stick out 1/2 or so. Mark the spots on the former and drill 1/4 holes. The former has to be ply and strong enough to hold good. On the rear of the wing glue two hard wood blocks to the inside of the fuse and drill through the wing and into the blocks. Tap the holes in the blocks 10 -24 or 1/4 - 20 and enlarge the holes in the wing for nylon bolts.
Old 02-13-2003 | 01:57 AM
FlyingPilgrim's Avatar
My Feedback: (26)
You may also want to reinforce the rear wing holes by gluing down some thin ply around the holes so you don't crush the soft balsa or have the wing rip through the head bolts.
