Reload this Page >
Top Flite Cessna 182 build
Old 12-10-2007, 08:48 PM
  #251
polakowa
Default RE: Top Flite Cessna 182 build
Ya i though of that. Everything looks ok but it doesnt sit right. What I am gonna do is shape the tail balsa block and then see how the tail cone fits
Old 12-10-2007, 09:29 PM
  #252
polakowa
jsmeed,
Let me know how your plane goes. Specifically the top skin over the stab. Does it curve nice from the stab to rudder like in the plans or is more a half curve if not straight. Heck let see some pics, no? Figure if we are at the same spot why not.
Old 12-15-2007, 04:34 PM
  #253
jsmeed
polakowa,
Sorry for the delay, been a busy week. Attached are a couple pictures of the LH top stringer, trial fitted to the stab.
ID:	826258   Click image for larger version
Old 12-15-2007, 05:00 PM
  #254
polakowa
looking good. I see what i have done differently. I actually sanded down my aft stab the aerofoil slightly. I also did this to match my elevator thickness. Thanks for the pics. Keep em comin if you can and dont hesitate to ask me for some photos.
Thanks again.
Old 12-15-2007, 10:06 PM
  #255
bulletbob41
LOOKING GOOD[>:]
Old 12-17-2007, 01:44 PM
  #256
Harvest Fields
will the wings be removable or do you just have a rather large vehicle
Old 12-17-2007, 02:46 PM
  #257
SDCrashmaster
SDCrashmaster's Avatar
The "wing" is removable. It's one piece...81" long.
Old 12-17-2007, 03:36 PM
  #258
Harvest Fields
yea force of habit saying wings, sorry lol. ive been a builder of cars + bikes ( model and real ) , trainers rc planes , many tamiya models lol, and a couple of helis ( rapt and nexxus ) and im looking at a long term project and a test. i think this will fit the bill atreat. ive been building models for yrs but nothing too complex. gotta take the plunge one day eh!
Old 12-17-2007, 07:47 PM
  #259
Deadeye
Deadeye's Avatar
ORIGINAL: Harvest Fields
Please don't take this wrong; but if you've never built a balsa kit before, this is the wrong one to start with. I had three kits under my belt before I started this one, and about 15 under my belt by the time I finished it. It is a complex build, and you need to know some fundamentals of working with balsa and reading plans to succeed with this particular kit.
Old 12-17-2007, 08:53 PM
  #260
iron eagel
iron eagel's Avatar
[/quote]
[/quote]
I agree very strongly with the above statement, this is not a plane you would want to do as your first build. Try a Sig kit as a start, the 1/6 or 30 size cub will hone your building skills.
Old 12-18-2007, 02:11 AM
  #261
Harvest Fields
advice noted and taken. ill look for something simpler. thanks for that. im not into 3-d or acrobatics so something " realistc " is what im after.
Old 12-18-2007, 02:56 AM
  #262
polakowa
carl goldberg anniversary cub is relatively simple and realistic
Old 12-18-2007, 03:00 AM
  #263
Harvest Fields
cheers. ill have a goosy at that one.
Old 12-18-2007, 10:19 AM
  #264
Deadeye
Deadeye's Avatar
A 'goosy'? LOL (language barrier). The SIG kits are of excellent quality and fairly easy and cheap to build. The Somethin Extra (am building my third one right now) and Four Star both go together quickly and will teach you loads before tackling something like the Top Flite kits. Good luck on whatever you decide, and remember if you have questions to post them here on RCU.
Old 12-18-2007, 10:38 AM
  #265
Harvest Fields
goosy = goosy gander. gander means to look lol. ill keep it less norfolk next time hehe.
Old 12-18-2007, 10:42 AM
  #266
Deadeye
Deadeye's Avatar
'Goosy' = pinching somebody else's arse. I am also aware my real name is quite hilarious in your country.
Old 12-18-2007, 11:03 AM
  #267
Harvest Fields
true, i find it particularly funny cos i have only one eye. the other is " dead " lol.
Old 12-18-2007, 07:13 PM
  #268
Deadeye
Deadeye's Avatar
I meant 'Randy'.
Old 12-18-2007, 09:54 PM
  #269
WALKERS210-RCU
My Feedback: (36)
Question for anyone that has completed or close to completing the Cessna 182. It took some talking and a little begging <G> to get the wife to buy me the Cessna Kit. This is far from my first kit or plane for that mater, but I have a question in regards to the simulated corragution that is added to the control surfaces. I have made a test run at applying the strips to wood and then covering but the results are far from pleasing. I am still some time away from this point but I like to plan at least 8 to 10 steps ahead, that way I can change my mind as many times as needed. Thanks and Merry Christmas to all
Old 12-18-2007, 10:12 PM
  #270
Adibac
Glass those surfaces with 3/4 oz cloth, prime and paint. Its a lot easier than covering.....[:-][:-]
Old 12-19-2007, 12:49 AM
  #271
SDCrashmaster
I think you glue the styrene angle stock over the covering. I sheeted my entire plane with styrene, then painted, so am not sure exsctly what the plans called for.
But it seems that a covering iron would deform the styrene strips.
JMHO,
Paul
Old 12-19-2007, 01:16 AM
  #272
Deadeye
Deadeye's Avatar
ORIGINAL: SDCrashmaster
JMHO,
Paul
Right you are, Paul. It says so right in the directions. I was unaware that you sheeted your entier plane in styrene. Please give some details.
Old 12-19-2007, 03:02 AM
  #273
WALKERS210-RCU
My Feedback: (36)
Thanks for confirming what I thought, I did send this question to TF but some girl answered that it goes under covering. I tried a small section bu was no where close to being what it should be. Styrene is an option that I had completely forgotten about, worked with styrene for a long time.
Old 12-19-2007, 12:47 PM
  #274
SDCrashmaster
ORIGINAL: Deadeye
Well, my sole reason for using styrene was to achieve a surface that reflected the deformation caused by the riveting process.
After careful evaluation of several local 1:1 182's, I replicated each panel's shape and rivet pattern in styrene, and then Med. CA'd them to the balsa sheeted model.
I do wish I had lightened the sheeting prior to the styrene skinning as the fully sheeted and skinned model came in at over 15 lbs. (including nearly a pound of lead in the cowl to balance). But the skin looks very realistic. In these couple of images the people are Photoshopped in, but you get a feel for the surface detail.
Paul
ID:	829281   Click image for larger version
Old 12-19-2007, 08:40 PM
  #275
fcf
My wife just let me purchase another plane for Christmis This will be my second TP Cessna 182, a year ago my artistic son sat on my first model before it weas finished I did not have too much luck with monocote on the first model[:'(][:'(] this time I would like to glass it. Can some one tell me what I need and name brand?[sm=72_72.gif][sm=72_72.gif]
