 RCM Funster CG >
RCM Funster CG
RCM Funster CG
Old 10-22-2007 | 09:48 AM
My Feedback: (40)
Default RCM Funster CG
Does anyone know the location of the CG for the RCM Funster?
Old 10-22-2007 | 10:30 AM
KitBuilder's Avatar
Default RE: RCM Funster CG
I believe there is a 20 and 40 size. I have the construction article in one of my rcm's but not sure which one? . I'll rumage through some and see if i find it. I believe it's from the late 80's??
Mike
Old 10-22-2007 | 01:13 PM
My Feedback: (40)
Thank you Mike! Mine is the larger Funster (WS 72")
GO GATORS!
Robert
OTOW Ocala, Fl
Old 12-05-2007 | 08:31 PM
The CG range for the Funster is 3 1/4" to 3 3/4" back from the leading edge , beside the fuselage. Book specs. Mine is the rearward.
Old 12-06-2007 | 10:02 AM
My Feedback: (40)
Thanks "bado", I used the MAC formual and came up about the same.
Old 06-15-2008 | 05:31 PM
If anyone has one of these not built yet I would like to buy it. I was given a very old built one (72 inch) with a very old OS 91 in it. I use it very succesfully to carry up gliders. I removed the virtical stab and made two smaller ones which i installed at each end of the horrizontal stab. I converted it to taildragger. I made a cradle which i bolted to the fuse slightly infront of the canopy. I have had over 50 succesful piggyback launches without a problem yet. KOW. Till today It has been gliders up to 2 meters only. Today I hauled up a 3.5 lb 118 inch Bird Of Time against a 10-12 knot wind. It was a fight and full power all the way. I had people with gliders standing in line for a lift. What fun!.............................antiquefer
