 kit storage >
kit storage
kit storage
Old 01-08-2008 | 08:31 PM
mistermnkim's Avatar
My Feedback: (153)
Default kit storage
just wondering what is the best way to store a kit. i have a 1/4 scale nosen citabria kit nib in my shop in the rafters. not going to build untill this spring. is it ok up there? ive heard alot of people talking about keeping there kits in climate controled environment, like inside the house. is this a must?
Old 01-08-2008 | 08:36 PM
DavidAgar's Avatar
My Feedback: (108)
Default RE: kit storage
I store all mine in a climate controlled garage. I am not sure if it is needed, but I figure it won't hurt. Good Luck, Dave
Old 01-08-2008 | 09:00 PM
I store my kits in a non climate controlled garage, so I wrap the boxes in plastic sheeting and tape them up to protect them from the elements. Even though I live in a place that doesn't have extreme tempature swing to worry about the humidity levels do change quite a bit. It's worked for me.
Miguel
Old 01-09-2008 | 09:46 AM
CrateCruncher's Avatar
Outside in the garage for a few months, even a year or two, is probably no big deal. But humidity can be hard on kits because it allows mold and mildew to colonize ruining the wood and discoloring the outside of the box. Also, many kits use plans and instructions that contain high acid levels (like Bud Nosen's blueprints!) which will turn brown and crumble over time and the moisture accelerates this. Steel hardware rusts too. Folks who live near the gulf coast (salt air + extreme humidity) should definitely keep their kits inside air conditioned houses for longer term storage. Here in Central Texas an attic can rise to 140 degrees in August so thats also out of the question if you don't want canopies and wood to warp. I keep my kits stacked in a closet in my spare bedroom. Fortunately stacking isn't that big a deal with R/C kits because they tend to be made from heavy corrugated cardboard but there are limits.
I bought a Royal Pitts S-2 kit from a guy in Houston that had left it out in his garage for 20 years. The outside of the box which was originally white had turned dark gray. Although the wood looked new, the plans and instructions were orange/brown and crumbly, especially the top layers exposed most to the air within the box.
I bought a Proctor Nieuport 28 kit from an estate liquidator in Alabama somewhere. The box and contents were fine but the 1/32 plywood pieces had mildew/mold and had to be replaced. The blueprints had also yellowed but weren't crumbly. A receipt in the box showed it was purchased new in 1992.
I've never had problems with bugs or other vermin but I hear infestations can silently destroy a cherished kit over time.
This is an interesting topic. I'd be interested in hearing what the guys up North with basements and real winters do.
Old 01-09-2008 | 09:26 PM
GRANT ED's Avatar
I am storing a TF giant scale corsair kit at the moment for a future build. I just leave it in my house, so far so good.
My advice would be to avoid a place with big temp changes and aim for a middle of the road humidity. Too high or too low will probably eventually cause problems.
