Ace Simple Series Wings >
Old 03-08-2002 | 04:31 PM
Default Ace Simple Series Wings
These quick-builds are the latest fad in our club. Current debate is whether or not to sheet the wings. Anyone have experience with these planes one way or the other?
P
Old 03-08-2002 | 09:02 PM
Pete,
I've built a couple of these planes without sheeting. I use strapping tape for strength.
Mark
Old 03-08-2002 | 09:31 PM
JRC's Avatar
JRC
Default carbon fiber
If you want a stiff wing - get some of that iron-on carbon fibrer tape - and wrap a 1/2 strip clear arond the wing overlaping in the center - and use low temp iron to stick in place and then glue with oderless CA.
I would not sheet the wing with balsa or anyting like that - to heavy. Also a little hard to sheet as they come from a mold and don't have the shucks normally used to compress the sheeting into place - I guess you could use a vacume bag method if you have access to the equipment.
Just cover with lowtemp film over the CF or paint with laytex, etc.
If you want a real nice finish - cover with silkspan using water base polyurathane to stick it on - then sand and paint - losts of work for a quick little plane to bang around - but hey it's up to you how much time and effort you want to put into it.......
Old 03-18-2002 | 03:30 PM
My Feedback: (51)
Default Sheeting the wing
I sheeted the wings on mine and it only added 1 oz with 1/32 sheeting and 3m Super 77 glue.
