 Sullivan Push Rods >
Sullivan Push Rods
Sullivan Push Rods
Old 12-18-2008 | 06:52 AM
Default Sullivan Push Rods
Im thinking of installing these in my 1/4 scale cub, for the tail section, its about a 36 in run ,Any suggestions on wich rod to use? Thanks Carl
Old 12-18-2008 | 08:44 AM
MinnFlyer's Avatar
Default RE: Sullivan Push Rods
Use the blue ones
Old 12-18-2008 | 10:20 AM
daveopam's Avatar
My Feedback: (9)
I don't know about the color but some of these have steel inner rod all the way through. Unless you have a tight turn I would use these. I don't care for the ones with plastic inner rod with metel ends. Make sure you support these every 6" or so no matter which ones you use.
David
Old 12-18-2008 | 10:36 AM
MinnFlyer's Avatar
6" is a but much. Just anchor them to each of the fuse formers
Old 12-18-2008 | 11:31 AM
ORIGINAL: MinnFlyer
Agreed. Anchor close to each end and about every 8-10 inches (or at formers) midway.
Blue rods http://www3.towerhobbies.com/cgi-bin...?&I=LXFU93&P=7
Old 12-18-2008 | 12:49 PM
Hossfly's Avatar
ORIGINAL: carl01
Whichever rod you use, let me throw in one point: For the connectors at the control surfaces: where you exit the fuselage, I suggest using a long threaded rod with the unthreaded part stuck back into the nylon push rod and using the threaded end to attach to both your clevis/ball joint and the inner pushrod. This makes a very stiff pushrod at the exit area. I have seen numerous models with a bendable pushrod in this area. Not a good thing!
Old 12-18-2008 | 03:21 PM
Hi hossfly,
Well you did ask for suggestions. FWIW I don't like pushrods other than for the short throw for ailerons. I use a pull/pull set up for each elevator half as well as the rudder. They are lighter, much easier to route and they don't flex.
Merry Christmas,
Colin
Old 12-18-2008 | 03:52 PM
qldviking's Avatar
I'm going with pull pull on elevators and rudder on both my 1/3 pup and cub
