 Hog Diehedral >
Hog Diehedral
Hog Diehedral
Old 03-12-2009 | 06:19 PM
My Feedback: (65)
Default Hog Diehedral
Just picked up a Astro Hog for a quick buile and was wondringif anyone has built with reduced diehedral and at what amount you reduced it. Also how was the flight characteristics with the reduced diehedral.
Ron
Old 03-13-2009 | 03:00 AM
Default RE: Hog Diehedral
Ron,
I reduced it to 6º (per plans is 12º), I maidened it last Sunday, and it flyes perfect, predictable, have no fear to reduce it...
I don´t have much experience and have not flown any other Hog, but this is a plane that doesn´t produce any stress ehwn flying...
What engine do you want to use?? I use a Ys63, more than enough, not unlimited vertical but loops can be veeeery large..
I hope this helps..
Old 03-13-2009 | 06:29 AM
My Feedback: (65)
Hi Spanishflyer
I am planning on using an OS75AX for power and also thinking of reducing the diehedral to about 3 degrees.
Ron
Old 03-13-2009 | 07:12 AM
Ron,
3º in each wing? 6 total, I used also the stock landing gear for tail dragger gear.
Sure that the 75ax is enough, but you´ll need to put som lead on nose, I had to with the Ys 63.
But total weight is ok, no overweight.
Here is a pic of mine.
http://www.rcuniverse.com/forum/m_81..._5/key_/tm.htm
Carlos
