 EPP Profilm covering question. >
Old 09-26-2009 | 04:31 PM
Default EPP Profilm covering question.
Hi all,
I am in the process of building an EPP sailpane, & almost at the stage of covering. I have opted for Profilm heat shrink covering, & would like some advice.
I understand that I have to use 3M 77 spray adhesive on the EPP to attach glass reinforced tape, but do I use this 3M 77 spay again before applying the Profilm?
Also, when I used a similar heat film before called Solarfilm, I needed to apply Prymol to help adhere joints where Solarfilm attached to Solarfilm. Does the same apply when attaching Profilm to Profilm?
I guess any Profilm & EPP covering instructions would be useful, so if anyone has any links, then I would be grateful.
Many thanks.
Ian. UK.
