*** Ultra Sport Brotherhood ***
#302
RE: *** Ultra Sport Brotherhood ***
What Mike hasn't mentioned, is that moving the landing gear out also passes the TLAR (that looks about right) test.
It looks really goofy with the narrower gear.
#305
MinnFlyer,
I've seen the pics of your retract, aileron and flap servos mounted in the center of the US60 wing. It looks like a lot of the center section was cut out to install all the servos. I'm wondering if that compromises the structural integrity of the wing or is it irrelevant? I want to place the 3 servos in the center, but don't want the wing to fold on me.
#307
Mike will probably respond with some cool drawings..
But I'll throw in my $0.02.
As long as you don't compromise the main wing spars. And you fiberglass the joint, wing integrity should be fine.
There's no rule that says any center mounted servo must be perfectly centered on the center wing joint. In fact, you might be better to mount them side-by-side, with the center wing rib separating them. It all depends on what you want to accomplish.
#308
Had to think about that one for a bit, but I think I may have been giving the center wing ribs too much credit for holding stuff together. It is the main spars and joiners that bear the burden. Thanks for the responses
#313
ORIGINAL: blw
Side by side servos is a good way to use existing torque rods.
ORIGINAL: MinnFlyer
That's a waste of a servo IMHO
I'd have to agree with Mike on this one.
I can see two possible reasons why I'd use two servos on torque rods.
1. The torque/speed requirements are more than a single servo can muster. A high torque replacement is unfeasable (cost, or availablility, or whatever)
2. You want to some thing funky with throws. More "up" and/or less "down", for example.
In both cases, the builder wishes to retain the torque rods, and not have servos out in the wings. For whatever reason.
But then again, I can't see these needs arising on an Ultrasport.
#314
MI
I have build the US40, 60, and 1000, so my next project is going to be a Ultra Sport 120. I will use an OS 120AX for power. I have RCM plans for the US60 so will have to get them blown up to the size for the 120. This is were I could use some help from you guys on what % should I use.
Ken
Ken
#315
MI
Will I guess that was a bad ideal seeing how the 1000 could use the 120AX, oh well on to some thing new. Should have looked at the specifications for the 1000 first.
Ken
Ken
#316
Actually, if you build an US1000, you may want to consider an OS 1.60. I used an MDS 1.48 before it crashed....but that is another story
bel air bob
bel air bob
#321
Box Car,
I have an ST 3000 in my US1000, although I am playing with the idea of going to a moki 1.8 or 2.1 ( I also see that Moki has a 30cc gasser) any thoughts on this, or just stick with the ST3000.. What size prop were you using with your ST? I am currently using an APC 17x12 (or 13 I cant remember for sure) and getting about 7700 rpm static. I am wondering if I should be getting higher rpms... I am not sure how old the engine is, but it seems to run pretty good.. It hand starts easily, and runs well..
Any thoughts?
Craig.
Any thoughts?
Craig.
#324
ORIGINAL: gabarber
Looks like I'll be #67! I inherited an US 40 partially built kit from Minnflyer in a trade.
I'm excited already, and this is going to be my winter project!
Me thinks Mike is secretly building another US..
Considering all the razzing he took when he stalled out on his last build. (he did finish it after a while).. I don't blame him for keeping this build to himself....
