*** Ultra Sport Brotherhood ***
#701
RE: *** Ultra Sport Brotherhood ***
I'd like to:
1. cut the Robart Oleo strut to the length I need
2. solder the cylinder (cylinders?) they provided into the end of the strut
3. place the strut into the hole in the Spring Air retract mechanism
4. tighten the clamping screw on the Spring Air retract to hold the oleo strut in place.
Is this what you did? Notice that I do NOT want to pass a wire strut through the two cylinder's as the instructions indicate.
Thanks.
#702
I'm not sure we have the same model number of Spring Air's. Mine have a 3/8" bore to accept about 1/2" of the upper/outer portion of the Robart strut.
#703
My name is Scott and I am an Ultra-Sport addict.
It started is 1991 with my first US, a 60 that I got from another club member, at first I thought it was ugly, looked like the dead goldfish that was floating at the top of the tank back at my apartment, then I flew it, up, down, inverted, fast; the start of a great relationship.
It was also my first crash, inverted, fast, 10' off the runway at full throttle and I pulled up when I should've pushed down. The crash left such a trench it looked like Bugs Bunny dug it.
I was hooked, bought and built a 40, wore it out and bought the ARF, didn't care for it much, heavy, felt like it was made from the same material the box it came in was made from. Sold it to a kid on the street corner so I could buy another 40 kit.
The addiction grew, at auctions I started picking up US 40's and 60's, along with old OS SF engines to mate them to, that nobody seemed to want. Their loss and my gain. I took these Ultra Sports home, cleaned and fixed them up, found them homes with flyers who would enjoy them.
Now I have five Ultra Sports. Two are charged and ready to go for when I get the urge, the need to fly with speed, grace and confidence. One plane is on standby without an engine, and two kits that I bought after Ken and Mike got GP to make them again.
I think I am ready to be part of the Brotherhood. Just don't hold it over me that I am also addicted to the KAOS.
Scott
Scott
#704
ON, CANADA
Well, in a freaky twist of fate, I have ended up with my old US 40. Pretty much in the same shape I sold it in...cept for being in a nasty crash. Instead of fixing the nose/engine area, they chopped off the fuse at the firewall. Well, this will never do. So,
I am in need of someone to photocopy the plans of the nose area so I can rebuild this lil beauty so she can fly in the sky again. If anyone could help, I would be indebt.
Thank you
Carl
Thank you
Carl
#705
NC
Making progress on my US40. But I want to send some "props" to Lisa in Parts Support at Great Planes. I had some parts that were warped that would have made the wing difficult to build straight. The leading edges supplied with the kit and the ailerons were not even close to straight. A couple of e-mails to Lisa in Parts Support and she shipped out the replacement parts ASAP!
These days we read so much about crappy customer service and I wanted to post a happy ending story about customer service at Great Planes. Thanks Lisa!!
Back to the building board! I hope to have this plane ready by this summer.
Mark
Mark
#706
MI
ORIGINAL: Scirocco14
Mark
Mark
Ken
#708
I have to agree with GP customer service. I built a their CAP 232 two years ago and had to have the canopy replaced and the decals came damaged. I would have thought since kits are now a low priority with them that there would have been poor reception, but like you, they were right on top of things. I wish I had time to start my US kit. Yours is looking good.
Scott
Scott
#709
Anyone know if this is enough room for the wheel, they are the Dave brown gear? The 2.5" wheels fit nice between ribs, but i don't want to have problems down the road...
#711
Since the retract rails are slanted toward the front (the rear rail is lower than the front rail when the wing is right-side-up) the gear will already move forward when they deploy.
If you ever need them to go farther forward, just shim the back side of the gear rails
#713
What's the length of your gear from bottom of wing to center of axle? I think I have it set to around 5 inches and for that lenght I had to remove the rib.
#715
CO
Well after buying an UltraSport 60 kit soon after their re-issue, I began building, then after a pause of a couple of years while we moved from Texas to Colorado, I have finally finished. (Still have to break in the engine before flying it).
So of all the places I have talked about it on RC Universe, I decided the Ultra Sport Brotherhood board would be the lucky ones to see the pics.
I am a little rusty on building, having bought ARFs for my last few planes. My covering is also rusty. That’s why I didn’t take any close up pictures. ☺
But with any luck it will fly.
I had a covering scheme all picked out in my head, and even drew it on the smaller scale drawings that came with the instructions. However, when I began drawing it full size, I realized I had bitten off more than I could chew. So I just started putting stuff on the plane, hoping for a pattern to form with my scheme.
It didn’t, so I just named my Ultra, “Hodge Podgeâ€
And here it is:
And here it is:
#716
IL
I love it! It looks great and it will fly great! Your covering has so much more character than an ARF. I will put flaps on my next one. What engine/prop are you using?
#717
ORIGINAL: MinnFlyer
Yea, as I recall, my wheel ended up near the center of a rib too.
Mike, I seen in the thread where your wheel centered just past rib W3. but you used robo struts which I think are pretty short.. What kind of prop clearance do you have with your set up? I will go measure mine..
#718
ORIGINAL: smkrcflyer
#719
CO
ORIGINAL: dash008
It’s a SuperTigre G90. I have a 13X6 on it now. I haven’t run it yet, but will probably stick with that prop for a while.
#720
No I’m not using robo struts. This is my first set of retracts so I’m just following what other people have done. I think the wire gear that comes with the kit is around 4 inchs. The down side to longer struts is they will be more likely to bend when taking off and landing and it will affect the stance of the plane on the ground.
#721
Gonna get the retract and flap servo rails in today so I can sheet the rest of the wing and get it mounted to the fuse...
Has anyone added extra blocking to the front of the TE for hinges? I plan to use dubro hinges and the TE is not very thick, so i will add some stock at the hinge locations...
#723
hi gang
had an ultrasport 60 with retracts ARF which someone in our club had and could never get to to
fly right, he claimed. went thru about 2 other flyers with same result. was there one day on a
very bad flight experience and the flyer removed the equipment and offered it for sale. no one
bit 0n the offer so he headed for the trash barrel with it and I offered to take it as a freebe due
to its past history.
worked with it for awhile and finally made the decision to go the the incidence adjustment.
found the the horizontal stab had about 4 degrees negative incidence built in. so I made the
necessary adjustments and guess what? flew great until I had a deadstick from about 50 feet
on takeoff and lack of flying speed crash and trashed.
currently have a 40 size with will be a building project before long.
how do I join the brotherhood
I was very impress in the flyability after I made the corrections
thanks and happy flying
pt19 flyeer
pt19 flyeer
#724
My Feedback: (7)
[quote]ORIGINAL: Mustangman40
I plan on using the foam spray to make the wheel well
#725
I just wanted to report that my Ultraport flew today. It was a little windy and my intent was to just do some taxi trials but it just wanted to fly so I opened it up and let it go. Flew great!!.
I attach a couple of pictures of the bird.
Chris
Chris
