Engine thrust
Can anyone tell me how to measure the side thrust on the engine installation.
Mine calls for 2 degrees, but I don't know how to set it up.
Sidekick
Sidekick
Check out this other thread. The technique is the same whether you are measuring left / right or up / down thrust ...
[link=http://www.rcuniverse.com/forum/m_9798859/tm.htm] Tips and Techniques thread [/link]<br type="_moz"/>
Easiest way is using an incidence meter:
http://www.robart.com/how_to/incidence_meter.aspx
If you don't have one, check this old thread:
http://www.rcuniverse.com/forum/m_85...tm.htm#8510245
