 can ca be undone >
can ca be undone
can ca be undone
Old 07-14-2010 | 07:14 PM
My Feedback: (7)
Default can ca be undone
i screwed up on a tailsection of a kyosho spacewalker and already put ca on all hinges. Can i undo the ca and fix my mess up
Old 07-14-2010 | 07:42 PM
ggraham500's Avatar
Default RE: can ca be undone
sure. find some debonding fluid at your LHS in the ca display. I actually think its acetone but that only a guess. I use it to clean my fingers after aggressive (read that sloppy) gluing.
Old 07-14-2010 | 07:48 PM
My Feedback: (7)
i thought i saw some of that stuff. thnx for the advice but i just cut the hinges and will rehinge tomorrow</p>
Old 07-14-2010 | 07:50 PM
davidgeorge212's Avatar
were the hinges slid into the surfaces or did you put CA on them outside the surfaces?
* cause I was going to say, it is a lot harder to get CA undone on hinges. If it was a balsa part glued to a balsa part, CA debonder would work fine.
