RCU Forums
-   Kit Building (https://www.rcuniverse.com/forum/kit-building-121/)
-   -   Nothin' Extra Build? (https://www.rcuniverse.com/forum/kit-building-121/11011150-nothin-extra-build.html)
mikeh251 04-09-2012 01:48 PM
RE: Nothin' Extra Build?
1 Attachment(s)
here are some pics of the completed project. I had to put my heaviest spinner on for balance and add almost 1/2 ounce to wingtip for lateral balance. Its not that light, weighing in at 5lbs 13 oz. but I got my hatch and 5 cell battery pack and big motor and lots of glue and support braces. The color scheme is pretty wild and is all "Busch's" fault!!! It should show up well inflight though. The green is ultracoat, the first time I tried it. It works good.
mikeh251 04-09-2012 01:54 PM
1 Attachment(s)
some more
mikeh251 04-09-2012 02:23 PM
I think the plane is set up and ready to test. I sealed the hinge gaps, balanced it, mounted the switch/charge jack, secured tank/receiver and set up radio for dual rates, expo and all that stuff. I also added flaps on the toggle switch (Futaba 6ex) with some up elevator mixed together with them. The motor already has some run time. I chose a 12/4 prop to begin with. The plane is now hanging from the rafters. I will give it one more good inspection and then look for a decent weather day to take it out and get it trimmed out. We have had very nice Spring weather here as far as temps go, but the wind has just been howling away at 25 mph for 3 days now!!! Oh well, I want to let it sit a minute and go over everything with a fresh mind and make sure its all ready anyhow. Will let you know how I make out when I try it though. I am going to Fla to collect my folks and their vehicle end of week so it may take a couple of weeks. Thanks for all of your help and comments, I appreciate it.
