repair LMH after a crash
hi
I want to repair my LMH after my fist crash (I was many month ago...)
Here you can see how its rigth now: http://www.rcuniverse.com/gallery/ga...emberID=118036
So, I appreciate you advice in terms of:
1) how to upgrade the crutch to a aluminium version?
2) What mini servo a need ? I must replace a couple of them ?
3) I have rest of fuel at the bottom (inside) of the fuel tank, How can I clean and remove that?
regards
regards
RE: repair LMH after a crash
You can order the aluminum crutch with the crash kit from HeliHobby:
[link=http://www.helihobby.com/cgi-bin/addToCart.cgi?userid=6460707&product=L1-90637%20110%20/%20120%20Aluminum%20Conversion%20kit%20and%20crash %20kit%20&price=99.99&qty=1&units=1&return=www.helihobby.com/html/LMH10.html]helihobby.com[/link]
You could also use a carbon fiber frame, like the ones that Matt offers at his site:
[link=http://ballistictechnology.com/products.html]http://ballistictechnology.com/products.html[/link]
I have ordered and installed several of the upgrades. The quality of the parts are extremely good and make the Corona fly and endure much better.
Ipoblete,
1) About the crutch, If you decide to go with one of the Ballistic crutch make sure you let Matt know that you have a Vmax engine and not electric.
Cause his crutches is designed for electric power...
2) Servos, how destroyed are they? can't you just get new gears for them ? would save you alot of $$.
You might want to go with metalgear on the cyclic servos and plastic gear on the tail..
3) Try to put some new fuel in the tank to disolve the old fuel, if it don't work, get a new 2oz tank.
I have a scan of the original LMH 116 crutch in wood let me know if your interested.
//Peter
//Peter
ORIGINAL: gadget01
i chechek helihobby and its out of stock, any idea on where I can get it? I can use another kit?
regards
ORIGINAL: Peter_d
Ipoblete,
//Peter
Ipoblete,
//Peter
about you reply:
2) some of them are 1005 destoyed, so i need to replace them. any model?
regards
Hi puble23
How can I know witch is my model? i'm not sure if is 110 or 120
regards
ORIGINAL: puble23
no you must use the kit for your helicopter.
For example the 120 has a longer tail boom and longer blades so it wouldnt work with a 110.
regards
