Lite Machine 110 ?????
You mite (???) be able to use the receiver and battery, but you will never get the servo's to fit (they are to big). Weight is the big problem, If you did get them all to fit in (receiver, battery, servo's) I think the heli would have a problem with the weight. The 110 is not a real power house. I have a 500mah battery in mine and I can tell the difference in the way it flies.
