lst reciever packs
PA
RE: lst reciever packs
ORIGINAL: fantomas
what would be the issue?? to many volts running through the receiver??
As long as both packs were hooked up parallel the voltage would remain 6 volts. As opposed to 12 volts if they were in series. I would think you should get longer run time if both packs were equal in capacity. Just like you wouldn't want to run 5 new batteries and 1 old battery together. Not as efficient. Personally I'd rather change batteries than carry the extra weight of a second battery pack. But that's me
