 Fly Eagle 1/6 scale F-16 Build Thread >
Old 10-15-2011 | 06:39 AM
  #476
My Feedback: (86)
Default RE: Fly Eagle 1/6 scale F-16 Build Thread
FB. Looks great man!
Rex
Old 10-15-2011 | 07:43 AM
  #477
FenderBean's Avatar
Thanks I really like the electric gear
Old 10-15-2011 | 09:13 AM
  #478
Hey FB,
Just got the weight the F-14:
40.66lb includes everything except:
pipes 1.28lb x 2
turbines k170   3.5 x 2
3 servos 8411
battery for turbine  2.7
fuel
pilots
i'm guessing total dry weight to be around 50lb
All the wires and airlines are installed with all valves and cockpit
Old 10-15-2011 | 09:54 AM
  #479
FenderBean's Avatar
It is the new material right?
Old 10-15-2011 | 10:00 AM
  #480
yes!
Old 10-15-2011 | 12:27 PM
  #481
icepilot's Avatar
ORIGINAL: FenderBean
Yelp your right simple fix thanks. When gear is up you can rotate the wheel if the servo is not install.
Yep, did that one my SM a few times!
Ready for maiden soon??
Old 10-15-2011 | 01:03 PM
  #482
Hey FB,
How do you set up taileron on the 14mz?
Old 10-15-2011 | 03:22 PM
  #483
FenderBean's Avatar
I would just use programmable mixing, with master and slaves, plus you can add conditions if its something you would like to turn on and off. I dont think there is a default servo setup you can choose but check those as well.
Old 10-15-2011 | 03:26 PM
  #484
FenderBean's Avatar
Yeah I had it ready to go and then I decided to convert gear, now I just have to run a few more servo extension and change some airline connections since I removed part of the air system. I'm also going drill my servo horns while its apart, I have my end points all the way down and still more throw than needed. I will drill and tap new holes closer in on the servo arm so I can increase the end points. The way it is would work but kills the resolution on the servo. SWBs are really more for 3D planes, wish I would have went with just a regular metal servo arms from JR or something. [&:] oh well lesson learned for next jet.
ORIGINAL: icepilot
Old 10-15-2011 | 03:36 PM
  #485
thanks will give it a try!
Old 10-15-2011 | 04:38 PM
  #486
FenderBean's Avatar
I had a jet with thrust vectoring that had it all like six mixes lol
Old 10-16-2011 | 04:13 PM
  #487
FenderBean's Avatar
Okay got the gear in and leads ran, added the up6 brake valve to my front board with a small HS-81 servo. The instruction say you only need 26 oz of torque for full pressure. the HS-81 does 36, and 46 on 6 volts. I also have the location of the DNL control box and the 7.4 volt ION for the gear.
I put the brake control on a side slider (right side) on my 14mz since its perfect for sliding in more pressure without getting in the way of your nose wheel controlling.
Old 10-16-2011 | 05:30 PM
  #488
I'm a big fan of brakes on slider. Right slider= brakes, left slider=smoke. Really makes it easy. Good call.
Shaz
Old 10-16-2011 | 05:38 PM
  #489
FenderBean's Avatar
Yeah because when your on the ground the right stick is not in play so this your left stick that's getting all action is not effected.
Old 10-16-2011 | 05:55 PM
  #490
Yeah because when your on the ground the right stick is not in play..........
that really depends on the jet, your 16 if you don't fly the ailerons on the ground till she slows down you can drag a wing tip in a heartbeat.
Old 10-16-2011 | 06:25 PM
  #491
Shaun Evans's Avatar
Hi,
I've had bad experiences with the UP-6 and servos that small. You might want to consider an HS-225.
Old 10-16-2011 | 06:30 PM
  #492
rcpete347's Avatar
My Feedback: (251)
HI, UP6, needs more ponies.
Rcpete
Old 10-16-2011 | 06:38 PM
  #493
FenderBean's Avatar
I thought of this since its such a drain on the servo at full brake. I will see how it goes I don't really need full lock at about half throw with min required torque the wheels are really tight. If it burns up the servo I will know, plus im running. Volts for the extra punch, not to mention im only applying brakes for short burst.
Old 10-17-2011 | 09:33 AM
  #494
My Feedback: (86)
FB,
An 8411 is your best bet for the UP-6 since it is proportional. The final part of the plunger arm is fairly heavy for a small servo. I have burned out 368's, 821's and 2721's...but finally found the 8411 is a winner.
Rex
Old 10-17-2011 | 09:36 AM
  #495
FalconWings's Avatar
My Feedback: (57)
ORIGINAL: KC36330
+1 ..........fly it to a stop!
Old 10-17-2011 | 09:51 AM
  #496
Yep,
I've burned out mini's (the 81 is a mirco) on the UP-6, especially when you're using a slider. It didn't take long either...
Old 10-17-2011 | 10:39 AM
  #497
You might actually also find that the way you intend to fly and stop is very different from when your jet is actually barreling past at 100 mph and you try and stop.[&:]
Old 10-18-2011 | 03:23 PM
  #498
FenderBean's Avatar
Well everything is back together did a test run on time for gear cycle. It takes 10 seconds for gear to go up and 11 secs for gear down. Not bad at all and thats on 7.4 volts so if you opt for lower voltage your cycle time will increase.
Old 10-18-2011 | 03:45 PM
  #499
bcovish's Avatar
My Feedback: (8)
What are you gonna do if you have to make an emergency landing of some kind other than the runway and have to get the gear up FAST. Oops, there goes the retracts. 10 seconds is a lot of time.
Old 10-18-2011 | 05:36 PM
  #500
FenderBean's Avatar
if I have to land any place other than the runway the gear would be up, since the only time its down is for landing on the runway. The time it took with door sequencing and gear down was only 3 sec less with air system. I think its plenty of time since it only takes about 5 secs to get the gear inside the jet the rest is just pushing it into the final lock pos. I know the pros and cons and I still plan on putting electric on all my future jets, my choice and Im happy with it.
Anyway, uploading a video showing the gear/doors working and a little better view of the locking of the canopy with the button valve.
Video # 56 http://www.youtube.com/watch?v=9jZw8REtZZ8
