Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Cox .Pee Wee conversion
Old 10-31-2011 | 12:44 PM
Default Cox .Pee Wee conversion
What would be the electric motor size equivalent to a Cox .020 Pee Wee engine?
Old 11-01-2011 | 02:25 AM
whitecrest's Avatar
Default RE: Cox .Pee Wee conversion
I think a 50-60 watt brushless would be about the same. I could just barely get a Goldberg Gentle Lady off the ground with one years ago.
Old 11-03-2011 | 06:39 PM
The standard rule of thumb would say 40W... but you'll probably be using a far larger diameter prop than the PeeWee could run, so you'll have a lot more "effective" power..... unless you need a speed demon... and then you'd went a high Kv 40W motor with a PeeWee-sized prop on it!
