Plane Cleaning
Hi there. I just bought an older crashed trainer and need some help. It was sitting a couple years, and was told that a mouse got into it. So I completey stripped this thing of all hardware and electronics. It is now an empty mostly-there trainer. As well, the main fuse area is dirty from dirt, cob-webs, etc. What can one use to clean up the inside of this thing? Pressure washer, garden hose, or would that affect the wood. This is just going to be a beater trainer for playing around with, and was told by others to totally scrap this one, and buy new. What are your opinions. The front was already repaired and is solid, just the tail is broken now. Also any help identifying would be great. OS LA 40, 64" wingspan tip-to-tip. Thank you.
It is a balsa sheeted fuse, no lightening holes, etc. All fuse covering is off now for repairs. Wing is in good overall shape. Just needs a few small patches. Thanks for the help.
BC, CANADA
bought, as you paid money for it ?? No way[X(]
its a bit of a project, but learning how to build and rebuild is as important as learning to fly.
Certainly suitable for a trainer.
Mount the main wing before re gluing the rear stab and line it up squarelly, epoxy would be best for a good bond
Unless it was given to you, it's going to cost at least $25.00 to recover the fuselage. Which club do you attend to fly from? Saints, WRCC or Steinbach? Just repaired and recovered a Tower Trainer 40 in ultrakote. I bought and flewthe planethe past 4 years, so I thought it was worth recovering.
Jim
Jim
My Feedback: (13)
for general cleaning I like to use a 50/50 mix of denatured alcohol and water in a spray bottle, and some paper towels work great for cutting the grease and grime, the mix evaporates quickly but willremove most of the oil you get from glow fuel.
as for the plane it would be handy to have the remaining bits of the fuse to get the rite H stab incidence otherwise the repair looks pretty minor in its condition just patch the areas where the film is ripped and get the tail feathers on strait and fly it like ya stole it if it survives you could recover it later but have fun first
Banned
This is what I make and use:
Airplane Cleaner
Mix into a gallon milk jug or equivelent-
*10 cups of distilled water
*2 cups denatured alcohol
*1 cup of ammonia
*1 cup of favorite dish soap ( I like Dawn)
Shake up lightly and pour into your spray bottle and use on your airplanes as you normally would.
This stuff removes bugs and oil of off non sealed- and sealed Solartex with a few wipe attempts and it cleans, Ultra, Mono and silk and dope aircraft. The stuff is so good I use it on the inside glass in my car. It leaves no streaks and it evaporates well.
A ol' timer wrote me about this homemade cleaner a few years back.
I figured I'd share it.
Pete
Re-edited because of mistake
Airplane Cleaner
*1 cup of ammonia
Pete
ORIGINAL: Oberst
Airplane Cleaner
Pete
Airplane Cleaner
Pete
Good stuff, Pete. Thanks for sharing.
CGr.
Banned
ORIGINAL: CGRetired
CGr.
ORIGINAL: Oberst
Airplane Cleaner
Pete
Airplane Cleaner
Pete
CGr.
Ahhhh!!!! I goofed! Let me do this one more time. I'm having a senior moment!
Airplane Cleaner
*1 cup of ammonia
I'm so sorry.[&:]
And thank you CGR for getting my post up, and thanks for the nice compliment.
Pete
A member at a club I used to belong with came up with this formula:
<span class="msg"><font size="2">"Jim Quinn's Mix"
5 cups water
1 cup alcohol (91% isopropyl or stove alcohol)
1/2 cup ammonia
2 tsp detergent
I carry a little two ounce spray bottle in my flight box (a recycled CA accelerator bottle). I refill from a two liter plastic bottle. I have used this for more than a decade on gas and glow models with no ill effects. I use Parson's Sudsy Household Ammonia and Dawn detergent.</font></span>
5 cups water
1/2 cup ammonia
2 tsp detergent
I used to carry a spray bottle of Simple green with, works great for cleaning the slime up, and smells good too, but it leaked, now my carpet in my truck smells good too.
ORIGINAL: Charlie P.
<span class=''msg''><font size=''2''>''Jim Quinn's Mix''
5 cups water
1/2 cup ammonia
2 tsp detergent
5 cups water
1/2 cup ammonia
2 tsp detergent
ORIGINAL: Jim_Purcha
Unless it was given to you, it's going to cost at least $25.00 to recover the fuselage. Which club do you attend to fly from? Saints, WRCC or Steinbach? Just repaired and recovered a Tower Trainer 40 in ultrakote. I bought and flew the plane the past 4 years, so I thought it was worth recovering.
Jim
Jim
I bought it for the attached OS LA 40. Was going to trash it as I just wanted the motor, not sure why as I fly electric. Just wanted the frusteration i guess. I fly solo. In the fields around here, or at the big field at the cottage. It will be around $50 to cover as the whole thing is geting done. The pics were taken when it got here, and I sterted to carefully remove the rear area, and none of it stuck at all, so removed it all. Same with the wing. Started to carefully cut out the rib bays where damaged, then realized that it too was not sticking. So I will recover the wing, and probably dope up the fuse as it is solid balsa. If it flies, it flies.
ORIGINAL: MTK
Hey, wait just a cotton pickin minute....Quinn flies electric and they don't need no stinkin cleanin
5 cups water
1/2 cup ammonia
2 tsp detergent
5 cups water
1/2 cup ammonia
2 tsp detergent
So, contrary to public belief, electrics need cleaning. Slimeless, but still cleaning...
Gerry
Simple green is a great product to clean the covering.No need to use full strength.Use 1/8 of simple green in average size windex bottle fill te rest of the bottle with water.If you have a lot of oil on the covering use a 1/4 of the product.
My Feedback: (12)
I like a mixture of alcohol, windex and Dawn. It even works on your hands after a day of fueling and fixing planes at the field.<div>With the price of used planes nowadays I will trash tha trainer and get an used one RTF for 100-150$$.
</div>
</div>
ORIGINAL: MTK
That's an Easy Fly 40 from Hangar 9 - you can download the manual from their web site. I had one as my primary trainer and fall back airplane for years. Can't tell you how many times I crashed, er hard landed
that thing and kept putting her back together.
I used Orange cleaner on her for the covering but eventually replaced the Ultracote covering with Monokote. And K2R works wonders for inside cleaning - soaks up fuel and vacumes well.
that thing and kept putting her back together.I used Orange cleaner on her for the covering but eventually replaced the Ultracote covering with Monokote. And K2R works wonders for inside cleaning - soaks up fuel and vacumes well.
Awesome, thank you. This helps a large deal to rebuild the tail section. There is a picture in the manual that explains it all to me now. Thanks again for all the great replies.
Well, I got the ammonia. Wow, is that stuff cheap. I looked for plain 'ol ammonia, but had to settle for lemon scented. So while sitting down, I cracked it and figured I'd give her a wiff to check out the lemon smell. Nothing lemon there, but I can now breathe easily through my nose as it is no longer plugged! Lesson learned, read the warnings..... But gonna mix a batch of cleaner up today and giv'er a try. Thanks again all.
Household is about 5% by weight. I worked at a photographic film plant that used 28% strength ammonia. One poor guy opened an inspection hatch and got a whiff and passed out - with his head over the opening. They found him there, dead.
I learned in college chemistry that when you need to sniff something you hold it away from your face and "push" fumes towards yourself by fanning your hand over the opening.
Lets be careful out there. ;-)
