Electric Indoor & Micro RC Flight Talk about this fast growing niche in rc. Micro radios, micro electric or co2 powered planes, heli's both indoors and out.
Air Hogs Aero Ace!
Old 07-16-2006 | 08:27 PM
  #1876
Default RE: Air Hogs Aero Ace!
or these?
http://www2.towerhobbies.com/cgi-bin...?&I=LXDE40&P=0
http://www2.towerhobbies.com/cgi-bin...?&I=LXK548&P=0
http://www.guillow.com/GuillowDetail...=28&FamilyId=1
Old 07-16-2006 | 08:35 PM
  #1877
i just got done test flying my peanut scale aa!
Flight #
#1-nose heavy- moved battery back.
#2-Still nose heavy- Moved battery back more.
#3-Tail heavy- Moved battery up a little and put anti-slide sticks around the battery.
#4-balanced good but has problems with snap rolling[:@]- added more dihedral.
#5-flew better but had interference/range problems[:@]
Hopefully flies better tommorow! ill trie to post pics tommorow too
Old 07-16-2006 | 08:37 PM
  #1878
Mine (up) is a 13 in span peanut scale rubber model, those should work if you keep it light.
Old 07-16-2006 | 08:47 PM
  #1879
does the penut scale fly alright indoors?
Old 07-16-2006 | 09:01 PM
  #1880
ive never tried mine indoors but it looks like it would in a gym when i get it to fly good
Old 07-16-2006 | 10:10 PM
  #1881
GTX SlotCar's Avatar
ORIGINAL: brimo
... I did the channel mod... changing it from a crappy B to a Great A frequency
Brimo, not all B channel AA's are crappy. I have 3 B's, all good; 2 C's, both good, and went through 6 A's, only 1 good. In general, I believe you'll find that the A channels give people the most trouble.
Old 07-16-2006 | 10:16 PM
  #1882
It is interesting tha back in the "old days' - about a month ago it was B channel that everyone was high on as the one with the best responce time. I have all three and have found I like them all (if they are not defective).
Old 07-17-2006 | 12:04 AM
  #1883
makg's Avatar
Yup, channel As are the worst, with Cs right in the middle in quality and Bs are the best...Thats what I heard a while ago, Airhogs might have improved them since then...
Old 07-17-2006 | 09:34 AM
  #1884
If the circuitry is identical for all 3 channels then the problems are likely caused by interference. Does anyone know the exact frequency of each channel?
Old 07-17-2006 | 09:49 AM
  #1885
I think the frequency is the same on all 3 channels, they just go by pulses/second. I think they are C=4, A=5, B=6. So the B channels should respond faster than the C, for example, but it's really hard to notice.
Old 07-17-2006 | 12:32 PM
  #1886
Test
Old 07-17-2006 | 12:34 PM
  #1887
My 4 operational AAs and this closeup.Show us yours!
Old 07-17-2006 | 12:38 PM
  #1888
I did'nt know how to post thumbnails,the program is free and it's called easy thumbnails,seems good and easy,for anyone whos interested.
Old 07-17-2006 | 03:49 PM
  #1889
Ayrton S's Avatar
Hey Wecky!
Glad you finally figured out how to post decent sized pics!
I'm not sure you need the thumbnail prog for RCU, I just downsize my pics a bit with B.I.M.P then when you do an image upload within a post, RCU produces the correct sized thumbnail for you in the post, with the option of clicking to get it full sized.
But you probably knew all that anyway!
Cheers
Ayrton
PS my park-flyer fleet including my Channel A X-twin is in my gallery...
Old 07-17-2006 | 04:34 PM
  #1890
Thanks "A" Cheers mate.
Old 07-17-2006 | 05:25 PM
  #1891
Anyone knnow if the AA jet is worth it as good as the AA or beter
Old 07-17-2006 | 06:54 PM
  #1892
monstermaker13's Avatar
better for me
Old 07-17-2006 | 09:03 PM
  #1893
how so? faster? more agile? Better quality? Also, does it need more space than the AA?
Old 07-17-2006 | 09:36 PM
  #1894
sama's Avatar
[8D][&:][>:][X(][:@][:'(][][:-][&o]
Old 07-17-2006 | 09:51 PM
  #1895
micro_builder's Avatar
here's possibly the heaviest AA i've seen. after folks were talking about having a 3rd channel for an elevator, i thought i'd try the BladeRunner RX i've got sitting around. i put in two 7mm SS motors, a .6 gram actuator for the elevator, and the Mini Rescue BladeRunner lipo. i flew it for about 4 seconds, which happens to be the exact amount of time it takes to realize that you put the left motor on the right, and the right motor on the left, and that right hand turn you just tried to make is actually a hard left, which pile-drives the plane into the ground the crash broke the verticle stabilizer and tore the leads off a motor, but it'll be fixed up for tomarrow.
this thing weighs 25.9 grams, and has tons of thrust, and with those two things, it should be able to take on 15 mph winds or higher.
nick
ID:	493043   Click image for larger version
ID:	493044   Click image for larger version
Old 07-17-2006 | 09:58 PM
  #1896
sama's Avatar
That elevator is incorret it will act as an aileron as its to the side put it in middle.
Old 07-17-2006 | 10:17 PM
  #1897
Neurotex's Avatar
ORIGINAL: googledperson
It's a good plane once you get it trimmed just right.
And chop some....faster than the bipe and takes the wind better.
Doesn't bounce about like the bipe either but landings take a little practice.
Old 07-17-2006 | 10:37 PM
  #1898
sama,
the elevator being only on one side works well actually. i've done it on a few other models, as have others. if both sides of the elevator moved opposite, then yeah they'd work as ailerons, but with only one, it just acts as a normal elevator.
neurotex,
that looks a heck of a lot better than the stock jet! so far the only thing i like about the jet is that i can fly it easily just inches off the ground. that and it glides much better.
nick
Old 07-17-2006 | 10:47 PM
  #1899
is there any difference between the aa jjet and the normal ????
I'm a noob but is there other frequences instead 27mh
Old 07-17-2006 | 10:55 PM
  #1900
FERNDALE AIR FORCE's Avatar
Wecky, here is the flyable AeroAce Ferndale Air Force. The monos are planes I refurbed. I have some planes in the hanger awaiting repair. The lime green plane has diodes for night flight. I recently lost a jet from the top of a tree, to a creek or 8+' nettles. Tim
