acetone
acetone
Hi from downunder.!!!
Someone told me to mix 2.5% acetone to your fuel to help
keep the engine clean and stop oil deposits etc.
I am running a Super Tigre S2000. and would or could this damage the engine?.Also what is the best engine/oil ratio for the Super Tigre's.?.
Regards & Thanks
Regards & Thanks
acetone
If you use Shell A for mixing, it already has 3% acetone in it. This is generally accepted to be a good thing, at least amongst us Aussies. Search this forum for "acetone" for more info.
As for Tigre Juice, I'm sure someone else will set you staight on this...........
