Go Back  RCU Forums > RC Airplanes > Seaplanes
 trying to find floats >
Seaplanes Aircraft that typically take off and land on water...radio control seaplane discussions are in here.
Old 03-07-2006 | 09:35 PM
Default trying to find floats
I am haveing trouble finding a place to buy some floats to fit my Sig Kadet LT 40. What I am looking for is some thing that I can put on and take off useing the standard set up for the regular landing gear. I don't want them to be a permanent fixture. Just some thing that I can quickly change when I am going to go to the lake that day.
Old 03-08-2006 | 01:17 AM
Default RE: trying to find floats
Forgot to say I was trying to find the ones from falcon tradeing co but I can't seem to find a web link that will work either.
Old 03-08-2006 | 01:40 AM
ArCeeFlyer's Avatar
Yes, the link I found is [link=http://www.falcon-trading.com/]http://www.falcon-trading.com/[/link], but who ever owns it now doesn't want anybody to access it, unless they are using subdirectories only.
I found a couple of links referring to them.
[link=http://mywebpages.comcast.net/chuenkan/RC-scale.html]http://mywebpages.comcast.net/chuenkan/RC-scale.html[/link]
[link=http://www.midwestproducts.com/2004%20Float%20Fly%20Flyer.pdf]http://www.midwestproducts.com/2004%20Float%20Fly%20Flyer.pdf[/link]
Old 03-08-2006 | 05:09 PM
Falcon Trading is NO MORE, they sold every thing out. I don't know who in the States might have a set of floats left but maybe by calling Midwest they can tell you where you can get a set. Midwest Phone # 1 800 348 3497, ask for customer service-- Ruth .
ENJOY !!! RED
Old 03-08-2006 | 07:48 PM
JimCasey's Avatar
Wow! that stinks.. Modelfly / Falcon Trading floats are very well respected. I hope that the Modelfly brand will resurface in the US market. The product were/are high quality and a good value.
Apparently SIG has never gotten the "smooth floats" right. I got word yesterday that Sig sent the latest batch back because the paint was not fuel resistant. This word did not come from Sig, so consider it with a grain of salt.
That leaves ZeeDoo floats from Hobby Lobby. They have been around for years and are great performing floats, too. A little hard to add a water rudder, but my attitude toward water rudders is well documented.
http://www.hobby-lobby.com/floats.htm
Of course you can always make your own floats. http://www.flyinglindy.homestead.com/skisandfloats.html this article will show you how to fab a tricycle mount, too.
Or you can order any of a number of foam-core floats...completely preferable to the ARF floats but they require a little work.
http://www.geocities.com/planefunfloats/
http://www.foamcorefloats.com/
http://users.cwnet.com/zdgreg/index.html
Old 03-08-2006 | 10:17 PM
Making floats out of foam following Chuck Cunningham's design is quite easy. I always make mine out of balsa-sheeted foam and they come out quite nicely, work well and are rugged.
Old 03-08-2006 | 10:21 PM
Thank for the help. What kind of foam do you use in makeing them right?
Old 03-08-2006 | 11:05 PM
seanychen's Avatar
I have the 60 size Zeedoo floats on my UCD3D. Here is a video.
http://www.pedrofrigola.com/UCD7Lake.wmv
I am sure the 40 size Zeedoo will be perfect for LT40.
Old 03-09-2006 | 12:15 AM
I think I will give it a try on building them. Seems like I could to it for way less than buying the pree made floats. Just bought a raptor and I may hve trouble getting the wife to understand the cost of arf floats. Does not look to hard useing Chuck's plans. Makes it look easy to do. Nice U-Can do 3-D.
Old 03-09-2006 | 07:44 PM
Jim --- I'm hoping some one in the States picks up Modelfly also, I love their planes and floats. As many as I have I may need parts someday. The planes were especially good when we were traveling as they didn't pick up hanger rash like most planes.
ENJOY !!! RED
Old 03-10-2006 | 07:45 PM
White foam as available at most any home improvement store is what I have used. Use a fine toothed saw with many small cuts (don't be in a hurry to make the cuts) to shape the foam and then attach the balsa and sand smooth. After the backbone is attached and all other work is done I have had success with monokote as a finishing material. Seal the edges well.
Attached are a couple of pictures of planes with floats that I have made installed. One is an 80" Midwest Extra 300XS and the other is a Balsa USA Stingray. Both planes can be changed from wheels to floats (or the other way around) in less than 5 minutes. Hopefully these are of assistance.
ID:	423792   Click image for larger version
ID:	423793   Click image for larger version
Old 03-11-2006 | 12:10 AM
Going that way this weekend. Thank for the help. One of the guys I fly with has a jig that he built to help get the cut out right. Looks like it won't cost as much to just build them my self.
