 The Scorpion  Arrives >
Old 11-07-2006 | 05:45 PM
Default The Scorpion Arrives
Ok here it is ! for all you guys who have asked me by phone and E-mail for pictures of the new Aviation Design Scorpion sport here they are....... I hope that they pictures speak for themselves and answer your questions...
Malcolm Kay Models
USA Distributor
Aviation design Products
Delray beach Florida
ID:	556011   Click image for larger version
Old 11-07-2006 | 05:52 PM
Banned
My Feedback: (67)
Default RE: The Scorpion Arrives
Hi Malkom,
How much is that kit?
Are those flying stabs ?
Dimensions ?
Weight ?
Is this another one from Gustavo ?
Old 11-07-2006 | 05:53 PM
Banned
My Feedback: (67)
forgot to ask, how many schemes does it come in ?
Old 11-07-2006 | 07:37 PM
felker14's Avatar
My Feedback: (50)
here is specs from
http://www.adjets.com/
Span 70’’
Length 83’’
Weight 18 lbs
Old 11-07-2006 | 08:57 PM
rcguy!'s Avatar
My Feedback: (69)
Malcolm,
Been reading thru the assembly manual and I am confused on a few things. Maybe you can clear them up?
1. Description says all plywood bulkheads are premounted. Page 8 says to glue them in?
2. Stab servo requirement says 5KG on page 3 yet on page 8 it says 8KG?
3. Page 8 shows the elevator servos mounted into the ply mounts. Looks like the port servo mount has been altered to raise the servo up? Will a reverse servo be required? Page 9 shows this also.
4. Are the fin/rudder assemblies located any other place other than the single M3 screw to prevent rotation?
5. Do I understand that mini servos are used throughout?
6. Is the tailpipe included?
Lastly can you tell us the wing area and what size wheels are used?
Thank You.
Dave
Old 11-07-2006 | 09:49 PM
Dave, from the site it appears that the pipe is extra. I didn't see a price though for the model.
Old 11-07-2006 | 10:01 PM
rcguy!'s Avatar
My Feedback: (69)
ORIGINAL: rcumember
Seems the extra short pipe would be a special item that should be included?
Any other options available?
Old 11-07-2006 | 10:46 PM
Guys.....the short pipe is included in the kit price as sold here in the states....the servos required for the wings on ailerons and flaps are the hitech 85 mG's (metal gears ), that is because the mountings covers supplied are the same as the Phoenix because the Scorpion uses the Phoenix wings, but you can modify the openings to accept the larger servo mounts as used on the Phoenix elevator...which takes a powerful standard size servo, if you are intending to fit a 120 size turbine then I recommend larger servos.. .. for a P80 or smaller turbine the small servos are adequate......... the tailplanes are all flying A la AD F16, I would fit powerful servos here if I were you..
the formers are all fitted and glued in at the factory, we suggest that you go around the glue joints and check thoroughly and reglue where necessary for safety sake.... the finished article with a p80 weighed 17.5 lbs.....the twin fins are mounted on an alloy tube with anti rotation pins as well and secured by bolting through the tube...... the tailplanes are operated by a cast alluminium fitting that connects to the servo arm no reversed servo is necessary............
Johnny H... this an Aviation Design airplane,...........................
Old 11-08-2006 | 12:27 AM
Ron101's Avatar
My Feedback: (22)
I see it is being offered by one of RCU advertisers
http://utopia.rcuniverse.com/utopia/...altecarerc.com
Prices are listed
Old 11-08-2006 | 06:29 AM
Dave
I have just been advised by my UK dealer that my Scorpion will be shipped tomorrow, should have it in a few days (Ihope!)
The model looks good in the photographs. While the AD website description says "No glueing" the first thing you have to do is glue reinforcing plywood into the fuselage at the joint so I think we should take the "No glueing" with a pinch of salt or maybe a pinch of glue!
You may have to mount one of your elevator servos as per the shot in the manual depending on your radio and channel availability remember you have two ailerons, two flaps, two rudders and two elevators for a start, that means "Y" leading and/or servo reversing unless you are lucky enough to have a brand spanking new 14MZ like me, in which case you will have channels to spare.
I will be using Hitec 5225 digitals on the ailerons and 645 MG on the flaps with 5625 Digis on elevator duty, 5125 on rudder.
I will have to wait until I open the box to see if a pipe is included in the European kit, I don't think so, a bit dissappointing as the kit is the equivalent of $1,600 over here and you guys get it for around $1,350. I will use my spare Eurosport pipe cut down to size and a plastic bottle 2 litre tank.
You will get the unvarnished truth on the model when it arrives!
John
Old 11-08-2006 | 06:53 AM
rcguy!'s Avatar
My Feedback: (69)
John,
Thanks for the feedback. Keep us posted on the "build". Malcolm says the bulkheads are in fact glued in, but should be inspected. Probably good advice on all jets. The looks do grow on you!
I wonder if a Comp-arf Rookie tank will fit? Could save a hundred US bucks?
Dave
Old 11-08-2006 | 07:43 AM
rcguy!'s Avatar
My Feedback: (69)
Malcolm,
Thanks for the speedy reply! I'm still looking for wing area and wheel sizes.
Dave
Old 11-08-2006 | 07:49 AM
Dave
Couldn't find that tank on the Comp.ARF spares list. Do you know what page it is on? I was planning on a 2 litre plastic bottle but I would certainly prefer a composite tank if it is reasonable.
John
Old 11-08-2006 | 08:03 AM
rcguy!'s Avatar
My Feedback: (69)
ORIGINAL: john agnew
Dave
John
John,
Part #320610 or 320600
Rookie model
Dave
Old 11-08-2006 | 08:39 AM
Dave
Thanks, got it now, 69 Euros in the UK. I will wait until I get the model to see if the 120mm diameter will fit on the tank bearers, if not it's the cheap & cheerful plastic bottle!
John
Old 11-08-2006 | 08:57 AM
Hi john your scorpion was sent today to you,i hope you like it buddy.eric tells me he is very happy with them.we have a few coming here this week for stock,together with some storms.
Old 11-08-2006 | 09:33 AM
Mark
Thanks for the heads up! I hope I like it too! You will, of course, see a frank and fearless review of the Scorpion on these pages ASAP
John
Old 11-08-2006 | 11:21 AM
Cool buddy it good to tell everyone what you think of it,good or bad,as long as i do my job by keeping you all happy with my back up service everything should be fine.if its crap we will work on it to get it sorted,im hoping its great and you all have fun with them.malcom i hope to be coming to see you next year bud so i will keep you posted.
Old 11-08-2006 | 11:25 AM
Sorry i fogot to say i have put ALL the scorpion pics on my forum page.
Old 11-08-2006 | 12:58 PM
LEAVESLY.....................you betta git your ***** over here for Florida Jets,07 or the whole new world will forget what you look like..................and forget how you fly!!!!!!!!!!! givemy love too Sian
Old 11-08-2006 | 01:16 PM
Undecided's Avatar
My Feedback: (36)
Hello Malcolm
I am interested in a scorpion, do you have them in stock? price?
Thanks, Neal
Old 11-08-2006 | 01:58 PM
Robrow's Avatar
I have to say I do like the look of this one Mark, have any paying customers flown one yet ?
Rob.
Old 11-08-2006 | 02:51 PM
Rob
I hope to have the first one in the UK, will get it put together ASAP. Wren SS going in mine but it sounds like a Falcon would be pretty good too!
John
Old 11-08-2006 | 02:53 PM
Hi rob,no not yet mate,john agnew will have his this week somtime as it left the factory today,mine is on the way also this week.im told there fantastic!!i have been designing my own sport jet for 6 months now,it was going to be a quick balsa easy to build cheap model for everyone "BUT" im going with the dream idea of a mega custom jet built and rigged and painted and test flown by myself then sold on to what ever customer wants one.its going to be like orange county choppers they build for special customers that want a custom bike that only they have.if anyone is interested in this idea please let me know.
Old 11-08-2006 | 03:33 PM
Robrow's Avatar
Sounds great John, Falcon should go great in one, I'm looking forward to hearing your impressions of the kit, looks a pretty neat model to me, which colour did you opt for ?
Mark...good idea, I'm sure there would be a demand for a service like that.
Rob.
