E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
new Tx(Futaba 6exh)
Old 12-02-2006 | 08:03 PM
Default new Tx(Futaba 6exh)
hi guys got a question. just got a new Tx (futaba 6exh-fm) and i thought i would try it with my blade. the Rx that came with, is a R168DF. i have ordered the crystal proper for it but i am getting tired of waiting for it. what do i have to do in order to hook the Rx to the blade and replace the stock one and be able to use the new Tx. any help and pictures would be greatly apreciated thanks.
Old 12-04-2006 | 03:31 PM
Default RE: new Tx(Futaba 6exh)
If don't want to wait, take the crystal from the eflite tx and insert it int to the 6exh. Make sure you setup the 6exh before 1st flight. The crystal does work like this but some will mention that it is illegal (FCC rules) to do so. Anyway, I did it and still waiting for the FCC to stop by.
ORIGINAL: pitch
Old 12-04-2006 | 08:27 PM
ok so i now have the xtals switched. here is my problem...everything works the way it is supposed to except the throttle, there is no response. i went into the program and reversed the throttle(from where it was) and still nothing. the 3 in 1 will not arm, but, if i put the throttle all the way up and wait the 3 in 1 will arm, then if i move the throttle to a lower position both motors wll start up?[:@] so it is like the left stick needs to be flipped. but like i said this will only do this if it is reversed(now normal). if the switch is reversed back even on full throttle it will not arm. i am stumped [][]
Old 12-04-2006 | 08:44 PM
Old 12-04-2006 | 10:08 PM
The problem "pitch" is having is with channel 3.
Andrew, switch it back the way is was originally and try lowering the throttle trim and see if it arms. Maybe the subtrim needs to be lowered some.
Old 12-05-2006 | 08:58 PM
sub trim? when i put it back where it was originally it will flash as though it is going to arm then the light stays a constant red. the futaba sites says to go into the stick program the scroll to the throttle and rev it, then they go on to say that you still may have to go into the normal rev program and rev that but there is no other program from the stick program.
how you feeling anyway?
Old 12-06-2006 | 06:05 PM
I'm having the same problem.. did you fix yours? if so what did you do? thanks!
Old 12-08-2006 | 06:39 PM
i have a new sheet of programming for the blade if i find it works i will post it for you to try. but i would like to get a list for the pro specific not sure if what i have is only for the cp or is it both
Old 12-08-2006 | 10:42 PM
I took the crystal out of my blade tx and put it in the 6exh.. and used the settings sent to me by Kevin (thanks man) . the only issue I am having now is that the left Aileron servo is getting pushed all the way up and is not responding to the tx. One thing I could not program was the Swash plate.. It shows 1-5 and I can't figure out how to change it..[&o] help me! LOL! Never mind! Iset the swash plate and fixed the servo issue! Now I need to change the pitch curve because it won't lift off. Dang it! also I changed the pitch curve and noticed the swash plate is backwards (stick right - plate left) .. now to fix that what should I do?
Update.. I'm flying again! I screwed up and had the CH A on the swash at +80 instead of -80.. I had her in a hover and did a few tail in circles in the garage! Now just set the expos a little looser because right now they are touchy! Thanks Kevin!
Old 12-09-2006 | 01:19 AM
Hey Guys was wondering if you could send me the settings for this radio. As I to just picked one up on ebay tonight.
Old 12-09-2006 | 11:23 AM
all ya gotta do is paypal me and ol' Kevin! LOL! what do ya think? na... I will post a little later.. let me fine tune it a bit..
Old 12-09-2006 | 01:25 PM
Here are my settings for the radio. I am running stock motor, twin tail motor set up (Helidirect) ,plastic blades from JCSHobbies (increased pitch rods as recommended @Jcs website), stock Lipo. I have tested these settings outside today and did minimal flight due to windy blustery day. Now that i am becoming familar with the 6exh I will continue to refine it.. This should get you flying if you are running the same heli configuration as me. Keep in mind Iam using the plastic blades with added pitch. adjust yours as nessecary .. I'm having to input a little tail and I am trying to address that .. (it's a little twichy maybe adjust the pot on the bird ) Please post your findings as you set yours up to compare notes.. Many thanks to Kevin (enticer) for putting me in the right direction. He's Da Man! I made changes to his settings to fit my needs and get me airborne.. update.. I just flew it out in the 5-8 mph wind and she did as she did before .. flew like a blade! I did change my expos to 50 as they were still to fast.. REVR
1 rev
2nor
3rev
4nor
5nor
6nor
DR all at 100% up and down
EXPO all at 50% up and down
EPA all 100%
trim all at 0
N-TH
1 0%
2 35%
3 60%
4 80%
5 100%
N-PI
1 15%
2 40%
3 65%
4 80%
5 90%
I- TH
1 100%
2 75%
3 55%
4 75%
5 100%
I- PI
1 0%
2 30%
3 50%
4 70%
5 90%
HOLD -off
REVO set to on
-45 up
+3 down
GYRO set to on
+90% switch is up
+100% switch is down
SWASH set to 3-S
A -80
E +80
P +25
Old 12-09-2006 | 03:42 PM
now i have a couple different settings to try...just a matter of getting used to the new tx...she flies like a whole different bird with this tx...glad i bought it...i will aslo have to play with the settings some to suit my flying. but it is all about learning right? thank you everyone for your help.
Old 12-09-2006 | 04:07 PM
ORIGINAL: savage 40
I cannot take credit for those settings, they are settings I found posted on a forum. I am not sure which one.
Andrew, those settings should look familiar to you.
Old 12-09-2006 | 05:39 PM
"she flies like a whole different bird with this tx" Boy ain't that the truth! right into the concrete! DANG IT! new learning curve.. pitch, are using kevins settings? if not .. which? and what changes did you make?
Old 12-10-2006 | 01:26 AM
Thanx Guys[&:]
Old 12-10-2006 | 11:00 AM
My Feedback: (12)
I see a lot of posts of guys not using the eflite transmitter.
Is the supplied eflite ccpm transmitter inferior compared to using a mainstream tx ?
Old 12-10-2006 | 11:06 AM
No, it just doesn't have all the settings in the radio to get you confused! .. it allows you to fine tune the radio to suit your needs. One question I had was what to do with the old radio? I don't think it can be used with a plane as a buddy of mine wants to do..
Old 12-10-2006 | 04:10 PM
Sell your radio on ebay. You'll probably get about 20 bucks for it. I sold mine when I got the Futaba 6exh.
ORIGINAL: savage 40
Old 12-10-2006 | 05:40 PM
they do. they look like a combo of the two pages you printed off for me. there are some differences but , i put them in and it works great. by far the best base progrm that i have used, tried it today in the living room all was good. got to do a few tweeks but this is the one i am going to stick with
Old 12-10-2006 | 05:42 PM
the settings posted here above i put in value for value, as i said a few tweeks to do but it worked very nice.
i also think it worthy to note i am flying a dual tail setup and the stock rx
Old 12-10-2006 | 05:45 PM
you could sell it ...or if you ever have problems with your new tx then you have a back up and can still go flying
Old 12-10-2006 | 07:47 PM
Okay guyz, I think I got the throttle and pitch curves pretty close.. But if you tweak on them a bit post them so we can try them.. 1=0 2=40 3=70 4=85 5=100 % n throttle , n pitch 1=15 2=40 3=65 4=80 5=90 % this seems to be real close to stock feel.. I've been flying around with 5-8 mph winds and was doing okay but those curves might be a little off. And after the chain link fence jumped up in the air we'z done till we get some blade grips! Dang it!
