Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Tornado BB
Old 01-15-2007, 09:14 PM
TannerReagan
Default Tornado BB
I have recieved a Tornado BB from Redcat Racing. I have never touched a nitro car in my life. I put my fuel in it adjusted it the way everyone says(I think), but i just can't seem to tune it to run right. I am having very bad luck. I feel like selling it and buying something i know i will love with the money, or can i take it to any hobby shop and have them look at the car and help me tune it??????[]I don't want to have a wasted christmas.
Old 01-15-2007, 09:16 PM
ehroof
Default RE: Tornado BB
you need to break it in first, then tune it, take it to a local shop if you having a hard time
Old 01-15-2007, 09:18 PM
ehroof
put it 2 1/2 turns out on the high needle, flush with the collar on the low needle and try staring it. counterclockwise is out.
Old 01-15-2007, 09:26 PM
TannerReagan
flush with the collar on the low needle and try staring it. <What did u mean buy flushing with the collar on the low needle???
Old 01-15-2007, 09:29 PM
TannerReagan
I tried to unscrew the idle screw out like you said in my other forum and all it does is loosen the metal piece inside of the carberator, it didn't make it close. Or do u manually push it. And whenever i turn the throttle trim it closed it.
Old 01-15-2007, 09:30 PM
TannerReagan
And could it possibly be the clutch spring, a read a forum about it.
Old 01-15-2007, 09:35 PM
ehroof
try starting it off the ground, if the spring is bad the wheels will turn and when you put it on the ground or use the breaks it will die.
Old 01-15-2007, 10:14 PM
AllAboutFunHobbies
AllAboutFunHobbies's Avatar
You should do this to reset the carb, if you look down the barrel when the throttle is at full brake position you can see a small gap in the carb barrel if not then you need to turn the idle screw either Clock wise or Counter Clock wise till you have approximatlly a 1 mm gap. Once you have that set go to the low idle screw and be sure that it is set flush with outside edge. Next turn the High idle screw down Clock wise very very carefully till you feel it touch bottom it very important that you don't force it, you will break the needle tip or gouge it, then it will be junk, just be very very careful and feel for the touch down, now back it out counter clock wise 2 1/2 turns and you will have your carb reset to a good begining point to where the engine should start and run right there.
Old 01-15-2007, 10:16 PM
aviator2007
there's a ton of info in this post http://www.rcuniverse.com/forum/m_5271405/tm.htm
I got my car started by this post, first nitro car ever owned. I found that mine started after about 15 pulls with just about factory settings. My dad on the other hand dicked with his and had to use this post to start his car.
If you still can't get it started I'll be more then willing to take it off your hands
Old 01-15-2007, 10:18 PM
aviator2007
or just listen to allaboutfunhobbies. He posted as I was typing and he's saying the exact same thing that is in that link
Old 01-15-2007, 10:22 PM
AllAboutFunHobbies
One more thing, before yanking till your arm falls off, do this before you place the glow starter on the glow plug, you need to prime it if you don't know how here's what we tell people. Place a finger over the tip of the exhaust and give it a few good yanks in short bursts at the same time, you will see fuel flow through the fuel lines to the carb once it hits the carb give it one more pull, now it's primed and you should only have to give it a few more yanks with the glow starter on the glow plug. If it's cold outside you may need to get the engine warm with a hair dryer or take it back in the house and get it back to room temp.
Old 04-08-2007, 09:51 PM
jakenos87
i need help i'm new to this sit and i dont know how to post a forum. i have a TORNADO bb and my brake dics dont work the lining chip is not on thair no more is thair why that came off and now i have to buy new ones is it becuse something was loose i need help
Old 11-21-2007, 12:36 PM
catfish26
i have a tornado bb 2 speed and ran it at the track for the first time yesterday and my gears are all gone it wont kick in and go i was just wondering why it happend just bought new gears and dont want it 2 happen agin plz help and was wondering if there is anyway to get metal gears my email is [email protected]
Old 11-21-2007, 01:49 PM
rclynx
rclynx's Avatar
If your going to run at a track you should probably run a single speed and you won't have so many problems. Onlt time the 2 speed works well is if its a long flat track[&o]
Old 11-21-2007, 02:28 PM
catfish26
can i turn my tornado into a single speed what will be the out come
Old 11-21-2007, 03:08 PM
pede_187
Yes you can. A single speed with have more low end power and a little less top end but not that noticeable. It will let you achieve much higher speeds offroad.
Old 11-21-2007, 03:11 PM
catfish26
how do u go about doing that
Old 11-21-2007, 03:51 PM
rclynx
rclynx's Avatar
[link=http://66.226.4.160/itemdetail_part.asp?partno=02107]This[/link]and[link=http:////66.226.4.160/itemdetail_part.asp?partno=05126]This[/link] is all you need I think........you might get ehroof or someone to confirm it, I haven't done it in a while[&o]
OOP's heck I already forgot you need the brake arm also[].......single speed is different[&:]
Old 11-21-2007, 08:19 PM
ehroof
ORIGINAL: catfish26
you need this: http://www.clermontmotorsports.com/s...ear-set/Detail
http://www.clermontmotorsports.com/s...-clutch/Detail
http://www.clermontmotorsports.com/s...-vented/Detail
the 2 cluch bells are both steel and will do the same job, the hpi one is vented and which makes it lighter and keeps the clutch shoes cooler. its basically a direct swap
Old 01-04-2008, 06:29 PM
catfish26
i have a tornado bb and ever time i start it it goes full throttle if any body can help plzz do my first car so dont no much and the hobby shops are asses about these cars they wont help
Old 01-04-2008, 06:36 PM
Macanan
Macanan's Avatar
Have you checked the transmitter, on the right side of it to the front should be 2 knobs one is trim for stearing and the other is for throttle make sure its not turned all the way open.
Old 01-04-2008, 06:52 PM
catfish26
yes i have somebody told me to look at my carb and its like when i start it it stays wide open
Old 01-08-2008, 06:52 PM
willashcroft
willashcroft's Avatar
You need to adjust the idle screw so it doesnt go forwards when just the engine is running.
