Project Monster Force
#155
hey try www.rccrawler.com they can help you with all the solid axle and links and stuff but not so much with the nitro. try it they are really helpful
#157
Well here is the list!
Well guys here is my project parts list!
Madd Force Adaptor Kit
http://www.maximizerproducts.com/maxstore/stores/1/Madd_Force_Adaptor_Kit_P83C8.cfm?UserID=224729&jse ssionid=2430905e0200$F5H0$FB
My clutch combo
Hot Bodies Flywheel for 2pc Shoe Lightning
http://www2.towerhobbies.com/cgi-bin...p?&I=LXHZK7&P=
Hot Bodies Clutch Spring 3-Shoe Lightning (2)
http://www2.towerhobbies.com/cgi-bin...?&I=LXEPA3&P=7
Golden Horizons Alum Clutch Shoe Prpl Savage 21/25/28SS
http://www2.towerhobbies.com/cgi-bin...?&I=LXFZZ8&P=7
My diff set up
HPI Bearing 10x16x5mm Savage 21 (2)
http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
HPI Heavy Duty Differential Shaft 14x34mm Savage (2)
http://www2.towerhobbies.com/cgi-bin...?&I=LXGJU3&P=Z
HPI Alloy Diff Case Savage X SS
http://www2.towerhobbies.com/cgi-bin...?&I=LXPLW0&P=Z
HPI 4 Bevel Gear Differential Shaft 4x27mm Hellfire (4)
http://www2.towerhobbies.com/cgi-bin...?&I=LXLZX9&P=Z
Hot Bodies Differential Gear Set Hard Steel Lightning
http://www2.towerhobbies.com/cgi-bin...?&I=LXLGV5&P=X
Hot Bodies Bevel Gear Spiral 10T Lightning
http://www2.towerhobbies.com/cgi-bin...?&I=LXJBM3&P=X
Hot Bodies Bevel Gear Spiral 43T Lightning Stadium
http://www2.towerhobbies.com/cgi-bin...?&I=LXJBM4&P=X
My drive shafts
Hot Bodies Heavy Duty Dogbone
http://www2.towerhobbies.com/cgi-bin...?&I=LXJKM7&P=7
Replacement parts
Suspion arms x2
3speed gears
brakes
kyosho long drive cup
center bulk
body posts
kyosho engine mount
bell guide
3pice clutch nut
Wheel and tire combo
Big joe tires and wheels,
imex web rims,
maxx onroad tires
will have pics of the web and tire in a bit!
Lst2 shocks
carb bolt for the mach
new ball bearing in the diffs!
Well thats it for now! I will keep u updated!
My clutch combo
My diff set up
My drive shafts
Replacement parts
Suspion arms x2
3speed gears
brakes
center bulk
body posts
kyosho engine mount
bell guide
3pice clutch nut
imex web rims,
maxx onroad tires
Lst2 shocks
#158
Now i understand why you want that python skin anodizing. Im sorry to hear about your loss, i know its a snake but a pet is a pet. And i hope you get better soon.
This is a nice project your working on and i would be glad to help out. I'll get to work on the python design as soon as i have some time to play around with colors and patterns. Byte and I have been keeping it in mind and coming up with ideas to get as close to what you want as possible and i think we might have a really good plan. The only hold up is that we have some orders to fill in and other requests of colors and designs that were asked before yours but dont worry your on the list.
So far from the pics you've posted i really like the one with the black lst shocks or are those from your muggy? i dont know much about that truck but the shocks look like the aftershock shocks.
Keep working on it, im looking forwards to the final product.
#159
ORIGINAL: -SomeGuy-
Thanks man. those are the muggy shocks, i like to keep the truck lower so those should to just fine with thinner oil and a softer to medum spring!
And the mach from the muggy is going to be sick!
#160
1 Post
Scanning over this thread, I noticed that the Hot Bodies and Kyosho helical gears are only 43T/10T bevels. This low gear ratio is what rock crawlers want, but I want to put helical bevel gears into a Savage. For Savages, they use a 43T/13T ratio and I want to keep this ratio for this application.
I know that HB does not offer a 43T/13T helical option, does anyone know if the Kyosho gears come in a 43T/13T helical option?
#161
Nope, They only come in as all i have seen is 43/10, the stock gearing in my truck is 43/10 so it won't harm me, but for u savage guys, there going to be a bit more low end.
#162
1 Post
That sucks. Those three miniscule gears would totally throw off my entire overal gear ratio in my Savages. I wonder if the Gigacrusher also uses the same Kyosho 43T/10T helical gears? If the Gigacrusher uses 43T/13T or higher gear ratio, does anyone know if these are a direct fit onto Savage diff cups?
#163
Hey guys i just got a werid idea?
I got stung by the drifting secne.
ANd i was thinking about making a drift force, that has a ring to it, "Drift Force"[:-]
But slaming the truck, and with the new axial .28rr uhhhh it would make a sick Drifter, put some slicks on it, or pvc. uhhhhh That would be sick!
What do you guys think?
#164
Why not? If you want to play around and have some fun, go for it. It would probably be a novelty- I am sure you would have some meaty tires back on there after a few PVC drifter runs.
#167
From: Bakersfield CA now watford UK, UNITED KINGDOM
Hi pythonfan will this work on my Mad Force Im not sure thanks.
http://www.jrradios.com/Products/Def...odID=JRP234275
#168
are u getting just the radio, or the radio receiver? if your getting just the radio, it will work, u just need to make sure u have the same crystals, but if ur getting the entire setup, with or with out servos, as long as it comes with the receiver, it will work just fine! unless u have a FM radio installed right now?
#169
Just want radio and reciever to work with stock servos my stock radio was no good.
#173
9 pages?o pythofan!!! 9 pages for a project that is at zero point! please dont imagine in 9 pages just do it the f***ing project! and at the kyoshomonster.com you did the same! and first af all this truck is not clean!
#174
ORIGINAL: The Winner
#175
and with my force i have 0 money!but i made it as is right know!yes but if you have zero money don't start your imagine in the forum one year ago!just be sure what you will make!
