RC Drifting Discuss all aspects of rc drifting here!
TT-01 discussion
Old 12-27-2007 | 10:09 AM
Default TT-01 discussion
This post is for all TT-01 owners, just post recommended upgrades pics videos whatever you want. just a general discussion post for TT-01 owners.
ID:	834948   Click image for larger version
ID:	834949   Click image for larger version
ID:	834950   Click image for larger version
ID:	834951   Click image for larger version
ID:	834952   Click image for larger version
ID:	834953   Click image for larger version
ID:	834954   Click image for larger version
Old 12-27-2007 | 12:26 PM
peetiewonder's Avatar
Default RE: TT-01 discussion
ball bearings, aluminum shaft, aluminum motor mount for starters
also lock the rear up and use puddy or sumtin to jam the front so that the wheels dont stall on switchbacks.
Old 12-27-2007 | 03:46 PM
Keep the ideas coming
Old 12-29-2007 | 11:49 AM
Here is a pic of my TT 01. It's the orange '86 Toyota.
Upgrades: Locked diffs all the way around, oil filled shocks, and all the Tamiya standard upgrades (i.e. aluminum drive shaft)
http://www.youtube.com/watch?v=oPyx2ZNaG_Y
Old 12-30-2007 | 05:32 AM
my esc came in so next session we will have a tt01 showdown!!!!!!
Old 12-30-2007 | 06:37 AM
Good video with nice led's they look good
keep on posting peeps I should have some pics of my car uploaded by tonight.
Old 12-30-2007 | 06:41 AM
Hi just wondering can somebody please put some info on the post and pics if you can on how to lock the rear diff and if you should lock the front diff and if so how to lock that aswell.
Old 12-30-2007 | 08:16 AM
On a TT-01 I dont Recommend locking the front Diff, this tends to cause understeer problems and while it does allow you to hold a wicked drift it can cause frustration on a Technical circuit..
Locking the rear Diff can help assist in the steering Bias a TT-01 suffers due to chassis layout, Having the Batts on oneside and the electrics on the other can cause the TT-01 to turn better to one side.. the easiest way to cure the steering bias is to cut the power, make the turn then pour on the power.. Please be aware that locking any diff can cause under steer if your TT-01 is also used as a street racer on rubber tyres...
If its just a drifter and you still wanna street race occasionally, then you can get away with a locked rear diff just be mindfull that its turning circle increases..
Locking a Diff can cause increased Tyre Wear and increased pressure on the transmission when using Racing tyres
Old 12-30-2007 | 11:07 AM
lol i was looking at vid somebody posted on it lol
Old 01-01-2008 | 08:40 AM
Pics coming tonight of my car
Old 01-01-2008 | 01:33 PM
Can somebody please tell me how to fit a new motor on my tt-01 because I am buying an orion element tomorrow or another motor if theres better at the shop.
pics will help greatly
Old 01-01-2008 | 01:44 PM
theres a couple of methods to lock a diff on a tt01. you can glue em or epoxy em shut, or u can remove one of teh tri bevel gears and fix it between the other two so that there is no movement in the tranny.
to change the motor u remove the six screws on the hood and the brace and remove the mount from teh motor and pinion from the motor and replace everything using the new motor.
Old 01-01-2008 | 04:07 PM
just saying Thanks very much peetiewonder he has been a great help and I would recommend him greatly for advice
Old 01-01-2008 | 06:11 PM
Can somebody please tell me where a good place to get drift wheels from is,
very useful post by the way.
Old 01-01-2008 | 06:22 PM
http://www.genkidoridori.com/index.p...c20c88d21bd876
Old 01-01-2008 | 06:38 PM
Hey, I am thinking of buying a TT-01 and was wondering if this [link=http://www.ultimatehobbies.com/istar.asp?a=6&id=TAM57765!1006]TT-01[/link] is good and what motor, esc and gearing should I use to drift it, and what else should I get for it other than aluminum drive shaft thanks. and is there any better place to buy this car or is this a good deal
Old 01-01-2008 | 09:21 PM
you can get drift tires anywhere, tower has the hpis, genki carries a bunch of others, oamuri.com has tires, or u can get abs off of ebay
Old 01-02-2008 | 06:06 AM
I would recommend the trinity komodo dragon or the orion element (both 19t motors), I am not to sure about an esc because mine is stock. full ball bearing set is recommended and any oil filled shocks, to keep your motor cool I would use an aliminium motor heat sink and aliminium motor mount. you will definetly need some drift tyres aswell so I recommend abs tyres.
Old 01-02-2008 | 06:18 AM
Hi I am hayden's friend and id just like to say this is a useful post
Old 01-02-2008 | 03:35 PM
ok thanks guys
Old 01-04-2008 | 08:31 AM
What does everyone think of the pics
Old 01-05-2008 | 04:00 PM
hopefully get some vids up of my car with the new motor- komodo dragon
Old 01-08-2008 | 03:12 PM
BUMP
Old 01-08-2008 | 04:00 PM
Fresh*'s Avatar
I have a TT-01 in need of a rebuild. It should be coming together in the next couple of weeks if all goes well. There are a few bits in the mail now and should be arriving sometime this week I guess. Then if I get a weekend to myself I will get to work on it and share some pics with you guys.
What is everyone running as far as diffs go?
At first I was running with the front open and the rear locked but I had oversteer problems. I then locked both diffs but the car suffered from some nasty understeer. I'm Thinkin I may need a ball diff up front so I am able to adjust for more of a LSD effect.
Old 01-08-2008 | 04:05 PM
joeyblaze's Avatar
The Goods:
3R CF Chassis
also:
10.5 BL novak system
GPM Alum lower front amrs
GPM Alum lower rear arms
Square RC one way shaft
3pm Futaba 2.4G FASST RX/TX
on with the pics
Ok well the first pics are of the Chassis and the Dif housing and other parts
This is a picture of the CF chassis drying after i gave a coat of Crazy Glue to all the exposed sides, even the counter sunk screws and what not
the only thing that was odd was it seems the front dif housing where the drive outshaft connects to center one way shaft is very long and deep, much more hollow then the stock one, and the one stock bearing was allowing to much play in the out putshaft, so i went out and bought another bearing so it has 2 and now it sits nice and snug. well on with the pics
i still have to retune it for drifting as far as camber and droop but the hard work is done
i know the bumper is on backwards, it wouldnt fit tight any other way
Please ask any question on my set up in the thread i have for it
http://www.rcuniverse.com/forum/m_6854741/tm.htm
