 Bvm Bob Cat Build thread! >
Old 01-24-2009 | 11:24 AM
Lasse Palm's Avatar
Default Bvm Bob Cat Build thread!
Guys!
Since it takes me one years to make a proper build thread in English,then you can keep your benefits with pictures and a short text in english!
The Americans who complain on Bvms prices!
I can only say that "we" in Sweden pay 30% in tax on all models from the U.S.A and 600 dollar in shipping for (example) one Bob Cat from Orlando to Stockholm (Sweden).
For me! It is about priorities!!
Regards
Lasse Palm
Team Jet Sweden
Old 01-24-2009 | 11:33 AM
Lasse Palm's Avatar
Default RE: Bvm Bob Cat Build thread!
Fuel cells in kevlar!
I use BVM hysol to put them together
ID:	1118065   Click image for larger version
ID:	1118066   Click image for larger version
ID:	1118067   Click image for larger version
ID:	1118068   Click image for larger version
ID:	1118069   Click image for larger version
Old 01-24-2009 | 11:37 AM
Lasse Palm's Avatar
Cockpit and Canopy
I make my own Cockpit/Clear canopy!!
ID:	1118072   Click image for larger version
ID:	1118073   Click image for larger version
ID:	1118074   Click image for larger version
ID:	1118075   Click image for larger version
ID:	1118076   Click image for larger version
ID:	1118077   Click image for larger version
ID:	1118078   Click image for larger version
ID:	1118080   Click image for larger version
ID:	1118081   Click image for larger version
ID:	1118082   Click image for larger version
Old 01-24-2009 | 11:41 AM
Couch Potato's Avatar
Hi Lasse,
Here's a tip for you.
When you do the cut outs for the main retracts, cut inside the pips on the fuselage, then dremel out to size.
It's easy to make the hole too big if you go to the pips on the first cut.
This is mentioned on the drawings but easy to miss.
Old 01-24-2009 | 11:57 AM
Lasse Palm's Avatar
Thanks dude!
Old 01-24-2009 | 12:24 PM
mr_matt's Avatar
My Feedback: (10)
Hi Lasse, it is super easy to do a full nose door as well, and it adds to the top speed (mine is pretty fast)
Don't cut out the nose gear clearance hole till you think about it!
Old 01-24-2009 | 12:30 PM
Lasse Palm's Avatar
OK!
Thanks!
Here is my friend Tommy Bäcklins nose doors installation.
He looked at my UB, and did the same solution, but "I" have not the time for that`s door installation[:@]
ID:	1118122   Click image for larger version
ID:	1118123   Click image for larger version
ID:	1118124   Click image for larger version
ID:	1118125   Click image for larger version
Old 01-24-2009 | 12:53 PM
Lasse Palm's Avatar
I killed my MGA pilot and made a new special LP-pilot
ID:	1118152   Click image for larger version
ID:	1118153   Click image for larger version
ID:	1118154   Click image for larger version
ID:	1118155   Click image for larger version
ID:	1118156   Click image for larger version
ID:	1118157   Click image for larger version
ID:	1118158   Click image for larger version
Old 01-24-2009 | 02:01 PM
Lasse Palm's Avatar
Main Gear installation.
ID:	1118212   Click image for larger version
ID:	1118213   Click image for larger version
ID:	1118214   Click image for larger version
ID:	1118215   Click image for larger version
Old 01-24-2009 | 02:14 PM
Lasse Palm's Avatar
Nose Strut Door
ID:	1118236   Click image for larger version
ID:	1118237   Click image for larger version
ID:	1118238   Click image for larger version
ID:	1118239   Click image for larger version
Old 01-24-2009 | 02:41 PM
Lasse Palm's Avatar
Stab linkage
ID:	1118273   Click image for larger version
ID:	1118274   Click image for larger version
ID:	1118275   Click image for larger version
ID:	1118276   Click image for larger version
ID:	1118277   Click image for larger version
Old 01-24-2009 | 02:56 PM
ORIGINAL: Lasse Palm
typically the complainers are the people who don't own a BVM jet, after owning one they typically stop complaining about the price
Old 01-24-2009 | 03:01 PM
Lasse Palm's Avatar
I have a small problem with the canopy framework!
The blue color on the silver color is not the best solution!
the blue color is not fixed.
I think BVM must look at this color problem
It was same problem with my King Cat canopy framework!!
ID:	1118299   Click image for larger version
ID:	1118300   Click image for larger version
ID:	1118301   Click image for larger version
ID:	1118302   Click image for larger version
ID:	1118303   Click image for larger version
ID:	1118304   Click image for larger version
ID:	1118305   Click image for larger version
ID:	1118307   Click image for larger version
ID:	1118308   Click image for larger version
ID:	1118309   Click image for larger version
Old 01-24-2009 | 03:13 PM
Lasse
I bought my BC last July, but didn't get round to finishing it until the end of November.
The instructions in the BVM kits are simply "The Best!" Like a good book, you get to the bottom of the page and cannot resist turning the page and doing a bit more!
Often I would say to my wife "I'm just popping into the workshop for an hour" and would go out there at 8pm, then come in at 1 am!
A thoroughly enjoyable build.
What engine are you putting in yours?
Do you intend to fly off grass? If so, I would highly recommend fitting trailing link legs such as the Jet 1A type. It does however prevent the main gear doors from fully closing, but does not seem to affect performance.
I would also recommend using the "crow" set-up as detailed in the manual. It makes slow speed handling very controllable.
Enjoy your build.....Look forward to seeing more pictures!
Old 01-24-2009 | 03:38 PM
Lasse Palm's Avatar
Worzey thanks!
I use a Jet Cat P-70 to my Bob Cat.
And my intend is to fly on grass fields with Bvm pro links
Regards
Lasse Palm
Old 01-24-2009 | 03:49 PM
Lasse
I too have a P-70 in mine..... Not the fastest Bobcat at the fly-ins, but good all round performance. Nice & light and with good throttle management, 10 minute flights on supplied tanks (I set my timer to 8.5 minutes then set up for landing)
Regards
Ian
Old 01-24-2009 | 05:20 PM
Lasse Palm's Avatar
I made mirrors of bad CDs to my Bob Cat!
I used the same CD on my UB..[8D]
ID:	1118375   Click image for larger version
ID:	1118376   Click image for larger version
ID:	1118377   Click image for larger version
ID:	1118378   Click image for larger version
ID:	1118379   Click image for larger version
ID:	1118380   Click image for larger version
Old 01-24-2009 | 06:08 PM
Lasse Palm's Avatar
Engine installation!
Jet Cat P-70
I am using a cord and plummet to get the turbin installation straight
ID:	1118427   Click image for larger version
ID:	1118428   Click image for larger version
ID:	1118429   Click image for larger version
Old 01-24-2009 | 06:19 PM
Lasse Palm's Avatar
More pictures!
ID:	1118437   Click image for larger version
ID:	1118438   Click image for larger version
ID:	1118439   Click image for larger version
ID:	1118440   Click image for larger version
ID:	1118441   Click image for larger version
ID:	1118442   Click image for larger version
ID:	1118443   Click image for larger version
ID:	1118445   Click image for larger version
Old 01-24-2009 | 06:46 PM
Lasse Palm's Avatar
This is my first Jet model with Futabas 2.4 GHz
I am not sure about the 2.4 Rx placement, does anyone have a pictures on Futaba 2.4 GHz Rx installation in a Bvm Bob Cat Composite!
Where is the receiver in the model?
Regards
Lasse Palm
Team Jet Sweden
Old 01-24-2009 | 07:10 PM
Lasse Palm's Avatar
I am waiting for JR/Futaba servos.
So I have started to decorate my Bob Cat with Promark dry transfers
ID:	1118477   Click image for larger version
ID:	1118478   Click image for larger version
ID:	1118479   Click image for larger version
ID:	1118480   Click image for larger version
ID:	1118481   Click image for larger version
ID:	1118482   Click image for larger version
Old 01-24-2009 | 07:38 PM
Lasse Palm's Avatar
I will use navlight from modellbaue.de
ID:	1118536   Click image for larger version
ID:	1118537   Click image for larger version
Old 01-25-2009 | 04:58 AM
Ali's Avatar
Ali
Nice work, I especially like the way the pro mark brings the model to life. I might try that with my new bobcat ( If I can keep it long enough ) Do you shoot clear over the entire airframe after applying the pro marks ?
Regards Al
Old 01-25-2009 | 05:20 AM
Pics of a Bob Composite with FASST 2.4
The first pic is with a PCM RX but the FASST one goes in the same place (i.e. the standard RX location on the radio plate). The second 2 show you how I have installed the FASST RX. It's not very pretty and am I sure you will do better but it works. I have about 10 flights on mine with no issues.
ID:	1119029   Click image for larger version
ID:	1119030   Click image for larger version
Old 01-25-2009 | 07:07 AM
Lasse, great idea how to make cockpit mirrors from old CD's.
Sicklick33, thanks for the radio tray layout, I'm just doing mine. First venture into Futaba FASST also.
I will be using 6014 Rx so hopefully no matchboxes.
Keep it coming Lasse......
I got mine when £1 = $2 last year.
