New Hitec Aurora 9-Channel 2.4Ghz Radio System
Old 11-10-2009 | 09:08 AM
  #226
rctom's Avatar
Default RE: New Hitec Aurora 9-Channel 2.4Ghz Radio System
Just an FYI I received my two bonus receivers (1 free and one half price, total $40) yesterday. It only took about 2 weeks from the time I sent in the coupon. Now that's a deal, an outstanding radio and 3 7 channel receivers for <$450.
Also I have one 7 channel radio in stock and available. Now have many flights in 2 different planes, as solid as it gets.
Tom Fawcett
Wild Hare R/C
Old 11-10-2009 | 04:52 PM
  #227
42etus's Avatar
I bit the bullet today and had my LHS order one for me. I went with the Aurora and a 9 channel rx. I had him order an extra 7 channel rx also. What's the deal with the coupon? Is it included with the transmitter, or do you need to send in a sales receipt to get it or what?
Now the waiting begins.[sm=sad_smile.gif]
Paul
Old 11-10-2009 | 04:58 PM
  #228
gjhinshaw's Avatar
My Feedback: (303)
rebate comes with radio!! You do need a sales receipt copy to send in.
Old 11-10-2009 | 05:39 PM
  #229
Bob Pastorello's Avatar
My Feedback: (198)
I received my radio yesterday from Tom Fawcett, WildHare....he got it on Friday - I had in my hands on Monday afternoon. Sent in the 7channel receiver coupon today.Cannot beat two 7 channel receivers for $40, no matter how you slice it.
I setup my GPElectric Yak effortlessly....I say effortlessly but that is after some angst....being a devout JR user for years, and Futaba before that, I kept trying to make it HARD. The Aurora is NOT *hard*. In fact, the program is so simplistic and direct that my own mental blocks were in the way.
Anyway - I overcame it and found my "Most FavoriteFeature" already....J1 is "elevator"....(J1 is a stick axis).... so...I can assign J1 to operate as many channels as I want. They all will retain individual sub trim, ATV, and will operate simultaneously!!!! For my biplane addiction, that means that I can assign all four ailerons to the same stick axis (J2, on my setup), and never use a mix!!!! WOW!!!
I also found a thing that is kind of hokey...at least on mine....when entering the model name, or user name, the little beeper-piezo installed under the display sounds like a cricket getting choked. IT's a strange sort of half-chirp, half-beep, and it only does it in the "keyboard" mode. All the rest of the time is sounds like a regular chirp thingy.
The only true "beef" I have is that the NiMh battery was / is crap. It would not accept the output of the charger to bring them up to spec, but for me that isn't an issue as I have a 2S 2500 LiPo that is now installed. I don't think I'll have to recharge before Spring.
The radio "feels" just wonderful, the gimbals are exceptionally smooth, and my JRstuff is OUTTAHERE!!!!!!!!!!
Old 11-10-2009 | 05:45 PM
  #230
My Feedback: (198)
Oh, I forgot something else REALLYimportant..... I put all three of my dual rates on the same switch...on this airplane, that saves me hunting around. One switch - pow - all three rates go full....the benefit of this is simply just not having to remember multiple switches. I can see Flight Conditions in my future with my big gasser Bipes.
Also - on Rudd&gt;Aileron and Rudd&gt;Elev (set this up in Camber Mix - Thanks, Tom Fawcett for discovering!!!), using NOswitch, just leaving "null", which means they are "active" full time.....and that is another switch I don't have to worry about remembering. I'll eventually assign "airborne adjustment" to these to make trimming my aerobats easier, but for right now, ONEday old, this is a pretty hot setup!!!!!!!!!!!
I'm smilin'......
Old 11-10-2009 | 05:57 PM
  #231
gjhinshaw's Avatar
My Feedback: (303)
ALL I CAN SAY IS....... STEP ASIDE JR, STEP ASIDE FUTABA..... THERE IS A NEW SHERIFF IN TOWN AND YOU ALL ARE GOING DOWN!!!!!!
Old 11-10-2009 | 06:36 PM
  #232
My Feedback: (13)
Bob....You still running A123 packs.
Does the telemetry feature work with this cell chemistry?
Greg
Old 11-10-2009 | 07:12 PM
  #233
My Feedback: (198)
Perfectly! It sends the airborne RX voltage being supplied to the RX.That is indepent of what chemistry. Volts is volts....and the TX displays the digits. Very cool. Cannot wait till the sensor package is available.
Old 11-10-2009 | 07:18 PM
  #234
Bob-You probably know, but just a reminder, that we can get into trouble (as in loosing an airplane) if we start depending on voltage reading with our A123 Rx'r packs, FWIW.
Old 11-10-2009 | 07:22 PM
  #235
Got mine yesterday (finally) TX charger shuts down after about 60 minutes, and won't charge the battery. Anyone else having issues like this?
  #236
My Feedback: (198)
Absolutely.....it's only there for the looks. I monitor avg. ma / min by measurement on all my planes, and keep close track of "on time" during a flying session. You are correct to mention it, though....we don't want folks WRONGLYthinking that measurement of voltage, loaded or un, on the A123 chemistry CAN be a predictor of remaining capacity when in fact it CANNOT. Good post!!!
Old 11-10-2009 | 07:24 PM
  #237
My Feedback: (198)
Yep. See my post...that was the ONEthing that sucked, for sure.
Old 11-10-2009 | 07:28 PM
  #238
Any recommendations for a 2S lipo that fits?
Old 11-10-2009 | 07:32 PM
  #239
My Feedback: (198)
I'm using a 2S2500 Zippy. Fits perfectly.
Old 11-10-2009 | 07:57 PM
  #240
Sorry Bob Can't seem to find a little more detail on the battery? Where did you buy, part number, please.
Old 11-10-2009 | 08:10 PM
  #241
My Feedback: (198)
HobbyCity.....HK...this particular one started life as a 3S, I simply removed a cell, rewired the connector, cutoff the original Hitec connector, spliced to replace the JR connector that was on the pack. EZ.
Old 11-10-2009 | 08:14 PM
  #242
My Feedback: (13)
ORIGINAL: Bob Pastorello
we don't want folks WRONGLY thinking that measurement of voltage, loaded or un, on the A123 chemistry CAN be a predictor of remaining capacity when in fact it CANNOT. Good post!!!
Bob...does the receiver battery get a load put on it to get the battery condition, or is the telemetry from the receiver battery real time reading without load. If there is a load what is it.
I'll also agree that an A123 cells remaining charge shouldn't be determined with a volt meter. Good point gsc116.
Greg
Old 11-10-2009 | 08:21 PM
  #243
My Feedback: (198)
THe telemetry is just whatever the instantaneous voltage is on the power buss in the RX, so it would be reflective of dynamic loads/unloads in flight....of course, you have to have another set of eyeballs watching the TX until the Sensor module becomes available.
Old 11-10-2009 | 11:08 PM
  #244
Bob,
Are you charging the lipo battery in the transmitter or taking it out and using the balance wires too.
Old 11-10-2009 | 11:22 PM
  #245
rctom's Avatar
I bought a 2150mah Lipo from Tanic for the transmitter, they will supply it with the Hitec connector if you ask. Be sure you get a 2S, the radio uses only 7-8 volts.
I charge mine outside the radio, have not even tried to do it in the radio. I also have tried a 6 cell eneloop nimh pack that I bought from batteriesamerica.com, it also worked fine.
TF
Old 11-11-2009 | 12:15 AM
  #246
Thanks Tom. I would just as soon go with the eneloops but have not found the battery on batteriesamerica yet. I did find a battery tray #6AAT, is this what you bought from them and put the eneloops in?
Old 11-11-2009 | 09:25 AM
  #247
rctom's Avatar
ORIGINAL: GhostRider32
No, just call them and tell them what you want. 3 wide x 2 long AA eneloop pack with Hitec connector and a 4" lead. Tell them to send you what they sent me the second time, they should remember that mine was wrong and they had to replace it, or send them a photo of your original pack.
TF
Old 11-11-2009 | 10:03 AM
  #248
i think it is to uue,but do not how fast it works,</p>
Old 11-11-2009 | 10:24 AM
  #249
Thanks Tom, Looking to pick up one of your planes in a few weeks.
ORIGINAL: rctom
No, just call them and tell them what you want. 3 wide x 2 long AA eneloop pack with Hitec connector and a 4'' lead. Tell them to send you what they sent me the second time, they should remember that mine was wrong and they had to replace it, or send them a photo of your original pack.
TF
Old 11-11-2009 | 02:01 PM
  #250
ORIGINAL: GhostRider32 Thanks Tom. I would just as soon go with the eneloops but have not found the battery on batteriesamerica yet. I did find a battery tray #6AAT, is this what you bought from them and put the eneloops in?
The dimensions of the battery compartment are 110 x 45.5 x 16 (L x W x H).
Refer pictures thread Aurora Battery Compartment posts 643 and 644.
Note page 13 of manual - Remove Lipol batteries and charge externally. refer:
Hitec Aurora, Eclipse, Flash, Optic, Prism series - Field and Fast Charging
Regards
Alan T.
Alan's Hobby, Model &amp; RC FAQ Web Links</p>
