Nutech 2wd oil fulled diff fitted to FG Marder
My Feedback: (22)
TX
How did you put the oil in the diff? Did you just fill up 1/2 of the diff about 60% before you put the two halves together or did you add it through a screw hole after assembly? Thanks.
Richard
Richard
yes just 3/4 full it then screw the end cap on .....if you have bought the complete diff it might come with oil in if it has try that first
My Feedback: (22)
TX
I finally received my two Nutech diffs, and when I opened them up to put in the silicone oil I found them both full of grease and no sign of any 0-rings to keep the oil in the diff! If I am supposed to remove the grease and then fill them up with oil, what is the best way to remove all of the grease! Also, where am I supposed to get the 0-rings to keep them from leaking? Thanks.
Richard
Richard
if you take them all the way apart you will find the orings there should be a oring and a plastic spacer on each axle and a oring on the main housing betwen both 1/2s
best way to clean the grease out is to use a bit of petrol will clean it up quick
My Feedback: (22)
TX
So, apparently they all come with grease and you have to remove it to make it oil filled! Ok! I can buy that, but I did not get an o-ring for between the two halfs! Would it be one that would likely be available at the local hardware or auto parts store? I won't know about the ones on the shafts until I get the grease out! Thanks.
Richard
Richard
#33
My Feedback: (22)
TX
I received an email from Ethan at Nutech and of course they ask me to check in the grease for the o-ring! But considering there is no grease where the o-ring is supposed to be that was futile! I do not know what they are going to do, but I asked them to send me the large o-ring that goes between the two halves! I did get the grease out of the other diff and filled it about 60% full of 50,000wt silicone oil, so we will see how that one does!
Richard
Richard
#34
great i so one diff has orings and one didnt ??? seems strange but nutech are great guys they will sort you out ..
#36
ok must have been made at 5pm on a friday
any automotive suppliy shop should have orings to fit
#37
My Feedback: (22)
TX
Bentley,
I finally had a chance to install the Nutech diff in my FG Stadium truck, and I seem to be having a problem with the handling of the truck ever since! I filled the diff up with 50,000 diff fluid as recommended and all seems well with the diff install, except that when I accelerate it wants to pull quickly to the left, and when I let off the gas it seems to want to turn quickly to the right! Can anyone explain why that might be, and do you think the new diff causing it? I have checked the rest of the running gear and all seems normal! Thanks.
Richard
Richard
#38
What you now have is torque steer because the diff is hooking up so much compared to before, I would go down in oil wt maybe 30,000 or go further to 10,000 then you can find a happy medium between. I know it is a hassle in a FG to remove the diff to do this but once it is right you will never look back.
#39
My Feedback: (22)
TX
RCkiwi,
Thanks! I thought that may be it! It seemed like an awfully thick oil when I put it in! Your right it is a pain to take the diff out of an FG!
Richard
Richard
#41
ORIGINAL: avconslt
Bentley,
Richard
Bentley,
Richard
#42
My Feedback: (22)
TX
I checked the alignment, etc. and all is set up properly, beside it ran fine before I put the new Nutech diff int it! I think RC Kiwi is right, it is probably torque steer and reducing the weight of the oil to 30,000 may fix it! I will find out tomorrow, as I bought some 30,000 diff oil today to try! Thanks guys!
Richard
Richard
