DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here
#451
CA
RE: DAMAGE SHIPPING/MISSING PARTS ISSUES____Post here
ORIGINAL: chebert
I have called and emailed dozens of times with no response and chatted which is a joke, I purchased this jet on 1/8/11 got it in opened the box and found the blades busted from the motor, then after building it I found that the tail rudder is warped, yesterday i decided to turn it on in my home to check out the servoes and gave it a 1/4 power and the motor made a nose but did not turn, I did smell a burning from the motor and esc, I have had all I can take from NP and if they don't make this right by 1/26/11 I will be filing a dispute with my credit card company, I may have gotten a lemon but bottom line is I paid a large sum of money for junk, they could at least replace it if not refund me.
Order yhst-17210252890263-169393
http://www.nitroplanes.com/69a01-red...ProductReviews
Good luck bro...
#452
FL
ORIGINAL: chebert
Go to the following link and see what the BBB has on Nitroplanes also know as Nitro Model Planes http://www.trustlink.org/Reviews/Nit...anes-205968257
Here is NP address and number supplied by the BBB
Contact: Ivan Wu
13240 Amar Road
City of Industry, CA 91746
(626) 369-2301
Contact: Ivan Wu
13240 Amar Road
(626) 369-2301
http://www.la.bbb.org/Business-Repor...anes-100031949
And more folks at N/P to try and reach, and more numbers to try.
Tony Wong (manager)
# 626) 968-9860
# (626) 261-4311
# (626) 261-4960
# (800) 820-3730
# (626) 968-9865
Only way to get their attention is file a dispute with your credit card company.
#453
AZ
I think it's my first time ever to post here, but from other forums, the link points to here so:
My order:
yhst-17210252890263-171496
has broken fuse inside a perfectly sound box.
this product:
http://www.nitroplanes.com/78a117-f117-camo-kit.html
I have pictures:
see below
It arrived today w/ tracking :
http://wwwapps.ups.com/WebTracking/p...3V030392156522
I must say that this is first time I have problem/ major issue with Nitroplanes.com, and I've ordered many planes from them in the past year.
I hope they can help me with this.
Thanks.
My order:
this product:
I have pictures:
see below
Thanks.
#454
LA
Order #1122479, specifically the spitfire http://www.nitroplanes.com/93a235-80...e-rtf-24g.html
As you can see from the order, I purchased the RTF version, but did not receive the receiver.
Thanks.
Thanks.
#455
My Feedback: (12)
MN
Just started going through my 50cc Suikhoi, 87.5" winspan. I found a 1" x 5" patch in the covering on the bottom of the plane. Over the years I've seen many planes but never seen one with a patch right out of the box. Started to put the landing gear on and could not find the lock washers - oh well. I have my own. Then I discovered the holes in the landing gear are 1/2" of the holes in the plane. So do I have the wrong landing gear or am I supposed to drill new holes. I know the price was cheap but the quality needs to be a bit better. Really- how hard is it to drill the holes in the right spot. I hope they make this right.
#456
I purchased this Nirto Plane from nitroplanes.com:
1 Nitro Gas P-51 U.S. Air Force "Stinky" Mustang 46 - 57/5\Radio Remote Controlled Airplane Almost-Ready-to-Fly
January 17, 2011
Order Number: 1123370
Website: http://www.nitroplanes.com/nigaspuairfo.html
Motor purchased: ASP S46A 2 Stroke Glow Engine with Muffler for Airplane
Problems thus far:
1 - The motor will not fit into the cowling. There is no way to arrange the motor so that the shaft will be in the center of the aitplane. (this is a major problem I believe. We selected a motor from the dropdown list. and I see no way thet it will fit this airplane.)
2 - The retractable landing gear will not fit into the desired location. They do not fit into the balsa wing. Also, we received 2 right wing landing gear housing, instead of 1 right and 1 left.
3 - I did not deceive any of the peices to secure the wheel to the rod (on landing gear) (looks like we need the 2 nuts? and 2 set screws.)
4 - The plastic wrap was put onto the cowling before the paint was dry and the paint is all messed up.
5 - The directions for the fuel hook-up are not clear, and I do not understand how to hook it up to the motor.
Please respond and let me know what to do with these issues. Thanks. Thomas
January 17, 2011
Problems thus far:
#457
VerticalPilot
Hi Thank for the picture I will reship 1x fuselage for you airplanes. And here are the UPS tracking number 1ZX03V030398479708
Eric
Eric
#458
I purchased the 2.4ghz Hawk Sky.
2.4Ghz 4 Channel
Dynam Hawk Sky Electric
Brushless Powered Glider
RTF
http://www.nitroplanes.com/60a-dy892...y-rtf-24g.html
Order Date: 01/25/2011
Order Number: yhst-17210252890263-172358
It came with two left wings instead of a left and a right. I need a right wing. Please respond.
2.4Ghz 4 Channel
RTF
#459
Since i saw forum support activity i thought i'll try again. Ididn't get a reply to my last post. Thank you.
ORIGINAL: alpiani
The order was placed on July 19th 2010at 10.00pm. Order number yhst-17210252890263-138012 . My original post was on August 8th 2010. Thanks
ORIGINAL: Forum support1
When did you order that airplanes are you sure is that order number cause when i check it with that order is was back in 2006.
Timmy
ORIGINAL: alpiani
Hi again. I wrote that message in a forum a while ago and still didn't get a reply. I thought i'll try again. Thanks
ORIGINAL: alpiani
Hi,
Order number yhst-17210252890263-138012 . Before putting the plane together i checked all electronics. All worked fine, except esc. It would cut of the power to the motor, make weird noises, reset all the time, shut down even at half throtle, it just wasn't working properly. I took the esc from my other samef-16 that i bought from you almost a year ago and problem was fixed. If it's possible could you send me a new esc. It was 25A with heat sink. Thank you.
Hi,
Timmy
#460
Hi alpiani
Sorry if I forgot to reply back to you yes I have found your order but is was July 2010 is almost a year old order and my company policy only warranty 30 days period.
Eric
Eric
#461
Yes I placed the order in July 2010, and my first post concerning the problem was on the 8th of August 2010 couple of weeks later, so within a month time. It took forum support a while to reply and then it was quiet again. It's not my fault. I also tried to call support but there was no way to get through. Even though i didn't get the problem resolved Istill bought two more planes from you guys (November). Istill hope I'll get reimbersed somehow for that bad esc.
Thank you.
Thank you.
Hi alpiani
Eric
Hi alpiani
Eric
#462
CA
ORIGINAL: alpiani
Thank you.
Thank you.
Hi alpiani
Eric
Hi alpiani
Eric
#463
IL
I just received my CMP J3 Piper Cub blue/white Clipped Wing 1660mm ARF Kit and the engine cowling that covers the motor was crammed into the box and had a crack down the side of it.
Almost half of the cowling !
Can you send me a replacement one for it?
NitroPlanes OrderID: 1144587
Plane I got http://www.nitroplanes.com/cmp-clipp...660mm-kit.html
Tracking Number: 1ZX03V030398260792
Exception Reason: ADVERSE WEATHER CONDITIONS
Read more: http://www.rcuniverse.com/forum/m_10...#ixzz1DQ92npgC
Posted in other section also before I found this one..OOPS
#464
Hi , I just got my shipment today but I also got broken plane in tail section.....
Order Number 1154642
Or(order yhst-17210252890263-175068
I sent the following email:
Hello,
I just opened up my Cesna plane but I found the tail section is broken. I have attached the pic with this email. The box from outside looked fine and the foam box wasn'tdamaged. Ibelievethis might have happened during packing. I have attached the pic. Sure I can glue it and fly but Ipaidalmost $200 and I wanted to keep this plane for a long time ,, I am not happy with this plane at all.
Tell me what can I do with it??
I sent the same email to sales and support but the person Ispoketo phone suggested me to send in this email to you as well.
I have not even opened anything from the plastic wraps exceptfuselage. I just had bad experiences with bananahobby but here is not working well as well...I think someone also in the post has similar problem and I am convinced that the shipping(warehouse )people who is doing packaging is making this mistake.
If you replace this brokenfuselagethat would work for me.
I have not heard anything back yet.......
#465
I needed a Cowl for a CMP YAK 140. I looked on your website and there was one listed. So I ordered it and it was shipped right away and when it arrived at my home I opened it was to my suprise it was not a cowl but a canopy. And yes it shows a cowl on the website and no; I do not need a canpoy.
My REF. Number is 1172207 2/22/2011. 844314 Shipping no. is1ZX03V030391275806
What do you want me to do with this canopy? Can you order me a cowl? And let me swap this canopy with you?
No one answes any of your phone no.s and your E-mail add. does not work either. I have been trying to get in touch with you for a week.
#466
yhst-17210252890263-178908
I got my SR 22 today with a broken rudder and a broken control horn on the Right aileron. See inclosed photos.
hfb
hfb
#467
I just purchased a yak-54 order number yhst-17210252890263-180181 and the aircraft is missing the prop spinner.
I also did not receive the art tech flight sim and usb cable that are supposed to come with the aircraft.
These items are in the review posted on your website, but were not included with my purchase.
http://www.nitroplanes.com/new2yak543da.html
Review here (per your advertisement): http://www.rcgroups.com/forums/showthread.php?t=904139
#468
My Feedback: (54)
CT
Hi
Just received my FMS B-25. Looks great except I did not get a spare set of props. From reading the ad it shows 2 sets? This is my order # yhst-17210252890263-179602. Thanks Paul
#469
LA
Hi John HELP,
I purchased the "CMP Piper L-4 72" Radio Controlled 35 EP Scale Airplane ARF Kit" and I finished building it yesterday but I found that the cowl is cracked when I took it out the box, I really would like to fly this beauty this coming weekend can you send me a replacement cowl for it? my order number is yhst-17210252890263-174845, please note if I do not get any help on this matter I will be forced into filing a credit card dispute for this order, which I do not want to do.
Clarence
Clarence
#470
FL
EDGE 540t 50cc
hi John ,
More importantly, im trying to find specs to see if this the best 3d plane for the money ,if mine doestn come wiht instructions ..all i need is th eC.G. please
what is your actual wieght? less fuel
what is the wing area sq in ches please?????
and actual wing span please,,as i find nitro planes wingpsans varies in whole inches!
thanks
Paul
352-212-3600
ps I see there on sale what price may i ask did u pay? if u sale your s let me see some pics please
[email protected]
oop rcu please post where i can get the most info on this plane,, thanks RCU guts this site is the BEST!
Hi John just received Wild Horse EDGE 540t 50cc plane no instructions came with it. Order # yhst-17210252890263-144908 . My email is [email protected] Thanks. Bill
Hide Signatures
#471
WY
these worthless ****s dont reply back it will be the last time I order from them ,japan is in crises **** no parts thats where they came from
#472
John, just received and unpacked CMP Piper J3 Cub 120, order No. 1283001, and all was well until I unwrapped the cowl. It's got a big chip in a very visible spot and hope you can send me a new cowl. Tkx.
Jim Wilde
6/13 Resolved. TKX.
Jim Wilde
6/13 Resolved. TKX.
#473
WA
Hi, I purchased a 91" J3 Cub from Nitroplanes and when it arrived the windshield was broken. this is the plane-http://www.nitroplanes.com/j3picub120en.html
I contacted cust support immediately and they said that they would try to find a replacement for me. Nice gesture but its been over 6 weeks and I have not heard anything. I do appreciate the effort but does it always take this long to get a replacementpart? BTW i noticed that there are replacement windshields for purchase on the Nitroplanes site, is there a reason they cannot send one of these? -http://www.nitroplanes.com/wiforcmppicu.html
Thanks.
Thanks.
#475
ORIGINAL: stick man
Thanks.
Thanks.
Hi what is your order number ?
Eric
