 GP RV-4 - How did you mount your receiver and battery? >
Old 09-15-2009 | 08:23 PM
Default GP RV-4 - How did you mount your receiver and battery?
I am at the final stage of completion of my RV-4 kit - the only thing left is to put a battery and a receiver and balance it! There seems to be plenty of room inside the fuselage, but I just can think of a good way to position the battery and the receiver so it doesn't look like a mess inside. My other problem is that I can't figure out a good way to run the antenna for the receiver either due to the fact that there a three very long push rods going towards the tail section... Any help would be appreciated - if you have built this kit can you snap a picture and post it?
Old 09-16-2009 | 09:38 AM
Default RE: GP RV-4 - How did you mount your receiver and battery?
Anybody? [&:]
Old 09-16-2009 | 10:45 PM
Pitts532M's Avatar
<div style="margin: 0in 0in 10pt">This was my first build after nearly twelve years away from the hobby and twenty building. I enjoy the plane and it has north of 50 flights on it.O.S. 46 AX, Pitts Muffler, switched over to 2.4 radio after I had flown the plane for awhile. I had added an antenna sleeve that took the antenna out the tail, it is clear colored; you can see it in the photos.Flaps with Go Slo added, does make the radio installation tight and interesting getting balance correct.Plane is Monokoted with fiberglass painted cowl.Added a more scale tail wheel. Plane flies great, is fast, flaps make it a floater on landing. I do routine aerobatics and an occasional snap-roll and spin with the plane.</div><div style="margin: 0in 0in 10pt">Hope this helps&hellip; </div>
ID:	1276848   Click image for larger version
ID:	1276849   Click image for larger version
ID:	1276850   Click image for larger version
Old 09-16-2009 | 11:02 PM
Pitts532M's Avatar
<div style="margin: 0in 0in 10pt">Pictures of my RV-4, post yours when finished; good luck and enjoy!
</div>
ID:	1276862   Click image for larger version
Old 09-17-2009 | 09:44 AM
Standard radio and servo setup for me as well... nice flyer with an OS70. Moves right along.
Old 09-17-2009 | 12:18 PM
Thank you, Pitts! This is exactly how I was planning on doing it, but I was not sure if the CG will be affected by the battery being so far back. I'm guessing you haven't had any issues so that's how I will proceed.
My other question is about the pilot figures - what scale is a good fit for this model?!? 1/5th maybe?
p.s. I will post pics once I've completed the model; I am working on odds and ends right now, but unfortunately I managed to f-up the canopy and I am waiting on my LHS to get me a replacement ((( I just called them and they said it might be another week or so, which sucks, because I was hoping to do the maiden this weekend. Oh well...
Old 09-17-2009 | 08:50 PM
Here are some pictures of the almost finished product Let me know what you guys think.....
ID:	1277241   Click image for larger version
ID:	1277242   Click image for larger version
Old 09-17-2009 | 09:40 PM
Pitts532M's Avatar
<div style="margin: 0in 0in 10pt">Devil&hellip;yep 1/5<sup>th</sup> scale pilot, mine is a Great Planes Pilot with a spacer added to get correct height. Good looking plane, she&rsquo;ll fly great! I mentioned before I changed the tail wheel to look a bit more scale, would be an easy mod for you even at this point if you would like to.Used a Sig scale tail wheel, works great in the grass or pavement; get lots of comments on the tail wheel from RV-&ldquo;X&rdquo; owners.</div><div style="margin: 0in 0in 10pt">Navy&hellip; real good looking plane too, love the RV series very colorful. </div>
ID:	1277281   Click image for larger version
ID:	1277282   Click image for larger version
Old 09-18-2009 | 06:37 AM
Thanks Pitts... I used a stronger tail wheel also but do not have a pic to show. The RV series is nice to look at; I agree. I took a sheet metal/riveting course when I had dreams of building a real one... kids college cost has put that to rest so I enjoy the RC instead. THanks for the pics of your plane; very nice.
