Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Glow Engines
 Anyone Tried The New Evolution .60NX? >
Old 10-10-2009 | 02:49 PM
SpinnerRow's Avatar
Default Anyone Tried The New Evolution .60NX?
Evollution has a new engine - .60NX - it is a .60 in a .40 size. This hobby is so addictive I tell ya. I'm itching to give the new Evolution .60NX a try. I have a SuperTigre G-51 with a pipe on a small 4lb 11oz plane and I'm thinking about putting one of these on it and give it a try with maybe an 11x7 or 12.x6 prop.
Anyone have one of these? RPM numbers? Prop recommendations?
Old 10-10-2009 | 06:20 PM
w8ye's Avatar
My Feedback: (16)
Default RE: Anyone Tried The New Evolution .60NX?
When you made your other post concerning this engine I looked and searched on the Horizon site and they do not sell a Evolution 60
I found the Evolution 61NT and 61NX. I then compared parts and the only difference is the cylinder head
Old 10-10-2009 | 06:24 PM
mike early's Avatar
He provided a link to this engine:
http://www.evolutionengines.com/Prod..._content=.60NX
Old 10-10-2009 | 06:27 PM
w8ye's Avatar
My Feedback: (16)
<u>We're sorry. No matches for "evolution 60NX" could be found</u>.
To find the 60NX on the Horizon site, you have to search for just Evolution and look through the selection.
To search for Evolution 60 doesn't return anything
Horizon has such a wonderful search engine
http://www.horizonhobby.com/Products...rodID=EVOE0600
To take the metric bore/stroke dimensions and multiply them out the displacement comes out to be 0.593540954 cubic inches
<div id="prodDetailInfo"><h2>Evolution .60NX Engine with Muffler</h2><!custom main tab text> <! end custom banner ><h4>Key Features</h4><ul>[*]Smaller size and lighter weight than typical displacement .60 engines. which leads to a higher power to weight ratio.[*]Fits smaller airframes where .60 size power was not previously available.[*]7oz lighter than competitive .60 size engines.[*]Deisgned to make use of aftermarket tuned exhaust to enhance 40 size plane performance by increasing power.[/list]<h4>Overview</h4>
The new Evolution .60 is revolutionary for modelers demanding the most from their engines. This new engine provides the performance of a .60-sized engine in the case size of a .40-size engine, allowing modelers to put more power into smaller configurations. The .60 will truly be a &ldquo;hot rod;&rdquo; it will provide modelers with speed and performance which has previously been unavailable in the .40-.60-size sport market. For the modeler who doesn&rsquo;t want to stop at the impressive speeds offered out of the box, the engine will be designed to work with aftermarket pipe systems to provide the ultimate in model engine performance.
</p><h4>Specs</h4><ul>[*]Type:2-Stroke Glow[*]Displacement:.60 cu in (9.73cc)[*]Bore:.95 in (24mm)[*]Stroke:.85 in (21.5mm)[*]Cylinders:Single[*]Total Weight:17.13 oz (487g)[*]Engine (Only) Weight:13.93 oz (395g)[*]Muffler Weight:3.2 oz (92g)[*]Crankshaft Threads:1/4 x 28[*]Prop Range:10 x 7 to 13 x 6[*]RPM Range:2000 to 17000[*]Fuel:10 % to 30% Nitro[*]Mounting Dimensions:44mm x 17.5mm[*]Muffler Type:Cast[*]Cylinder Type:ABC[*]Carb Type:Barrel, with two needles[*]Crank Type:Ball Bearing[/list]</div>
Old 10-10-2009 | 07:22 PM
SpinnerRow's Avatar
I saw a stack of them at my local hobby shop. [8D] They were loudly calling my name!
Old 10-10-2009 | 08:22 PM
proptop's Avatar
My Feedback: (8)
ORIGINAL: SpinnerRow
There's threads in the Classic Pattern, and Extreme Speed Prop Planes forums, but I don't think anyone's gotten one yet?
You can be the first kid on your block with one, and tell us how it runs! [8D]
Old 10-11-2009 | 03:40 AM
My Feedback: (14)
ORIGINAL: proptop
I have the OS .55AX (the first of this type of engine) and then I bought the Enya .61CX. Both are great engines, but neither match a contemporary state-of-the-art engine in power/performance. After all, they are running with less induction tract volume than the .45 and .52 sized engines from whence they came. They are good for muscling around a .40 sized plane, but neither is equal to a true sixty. I don't see why anyone would expect the new Evolution .45 based .60 to do any better. Maybe as well, but not better.
Ed Cregger
Old 10-11-2009 | 11:48 AM
SpinnerRow's Avatar
ORIGINAL: NM2K
ORIGINAL: proptop
Ed Cregger
I don't have any lofty expectations but at $149 I bet it is quite a bit stronger than your average 40-45 which is what I am expecting. I doubt it to be as strong as a 60 size 60 but who wants a 61 these days when you chan have a 75, 90 or 95 the same size!
Old 10-11-2009 | 04:55 PM
proptop's Avatar
My Feedback: (8)
Ahhh...so 60 is the new 45...and 90 is the new 60...I see
Old 10-11-2009 | 07:44 PM
mike early's Avatar
There's no replacement for displacement?
Old 10-11-2009 | 09:25 PM
still4given's Avatar
Jett took a .40 case and made a .60 from it and it is mighty fast.
Old 10-11-2009 | 11:04 PM
MJD's Avatar
MJD
And Jett did it a decade ago.
I agree proptop - the oversize thing has become de rigeur now. We have "small block" .76's from Jett now, where will it end?
I love it. I hope someone runs one of these and reports back soon. I don't think anyone is expecting miracles, but anticipation is half the fun - it will be very interesting to see what it does. As I recall, the .36 puts out some pretty good power in the 17-18k range. The specs and hype for this one indicate pipe timing, so with a good aftermarket exhaust lessee what it does.
MJD
Old 10-12-2009 | 09:06 AM
SpinnerRow's Avatar
I'm going to pick one up. I have a 60-90 sized pipe that I picked up at a recent swap meet that I need to try as well. I'm not real sure which Macs pipe I need to get to fit it though. I'll have to call Macs and see if they know unless one of y ou already know.
Old 10-12-2009 | 10:01 AM
blw's Avatar
blw
See how tight the pinch is before you crank it. I've seen them very tight. Have a hotter plug on hand just in case it doesn't like the OS 8 heat range..
Old 10-12-2009 | 10:06 AM
SpinnerRow's Avatar
ORIGINAL: blw
Pinch? Is this an ABC engine kind of pinch?
Like a #6 or a #7 (formally an A3)?
Old 10-12-2009 | 10:39 AM
My Feedback: (14)
ORIGINAL: mike early
Kind of like a 421 CID Chevy small block engine, I guess???
Ed Cregger
Old 10-12-2009 | 02:03 PM
SpinnerRow's Avatar
I was told that the header pipes I could use are Mac's number 2591 or 2590.
I plan on picking one up this weekend. I'm going to try an APC 11x7, 12x6 and a 13x6. I probably will tune the pipe to 12x6 if, like the Evolution web site says that, the engine can turn 12,000 on the 12x6. The pipe should make that 13,000 to 13,500 or more I'd think. Stupid strong motor for a 4lb 11oz plane I plan to put it on!
Old 10-12-2009 | 02:39 PM
blw's Avatar
blw
ORIGINAL: blw
This is a true ABC engine, but I mean like a non-ringed 2 stroke pinch at the top.
Yes, the A3 is perfect and necessary for the Evo .455, .46NT, .61 engines. The .52 runs very well with them too, but I'm not as sure about it being necessary.
Old 10-12-2009 | 05:26 PM
Horizon Hobby won't ship internationally.
Is there another US based hobby distributor or e-retailer who stocks these, and is happy to ship internationally?
Old 10-12-2009 | 05:43 PM
MJD's Avatar
MJD
Based on their hints at the timing and with prop recommendations down to 10-6, I'd be very interested to see what kind of power it puts out in the 16-17k range. 12-13k on a 12-6 is muffled generic big-block ABC .61 territory. Good power for sure! I really see potential for this engine in powering up various .40 pattern and sport speed designs, models that work well with 10" and smaller props and are designed to fit .40-.46 engines. Maybe it will be good for both.
MJD
Old 10-12-2009 | 06:26 PM
w8ye's Avatar
My Feedback: (16)
ORIGINAL: fiery
http://www.advantagehobby.com/produc...oductid=112766
http://www.advantagehobby.com/pages.php?pageid=12
<table cellspacing="0" cellpadding="0" border="0"> <tbody> <tr valign="top"> <td class="medium">
<span style="font-weight: bold;">Standard International Shipping Charges</span></p> </td> </tr> <tr> <td></td> </tr> <tr valign="top"> <td class="medium">$0.00 to $100.00:</td> <td class="medium"><span style="font-weight: bold;">$29.99</span></td> </tr> <tr valign="top"> <td class="medium">$100.01 to $200.00:</td> <td class="medium"><span style="font-weight: bold;">$39.99</span></td> </tr> <tr valign="top"> <td class="medium">$200.01 to $300.00:</td> <td class="medium"><span style="font-weight: bold;">$49.99</span></td> </tr> <tr valign="top"> <td class="medium">$300.01 to $500.00:</td> <td class="medium"><span style="font-weight: bold;">$59.99</span></td> </tr> <tr valign="top"> <td class="medium">$500.01 to $1000.00:</td> <td class="medium"><span style="font-weight: bold;">$79.99</span></td> </tr> <tr valign="top"> <td class="medium">$1000.01 and Up:</td> <td class="medium"><span style="font-weight: bold;">$89.99</span></td> </tr> <tr> <td class="medium">
Note: Oversized Items/Orders do not apply. See below for Oversized.
Note: Items sent to Canada are shipped via USPS due to their reduced customs brokerage fee.
Note: HAZMAT items can only be shipped within the 48 Continental States.
<span style="font-weight: bold;">Oversized Packages: International</span></p> </td> </tr> <tr> <td></td> </tr> <tr valign="top"> <td class="medium">$0.00 to $100.00:</td> <td class="medium"><span style="font-weight: bold;">$39.99</span></td> </tr> <tr valign="top"> <td class="medium">$100.01 to $200.00:</td> <td class="medium"><span style="font-weight: bold;">$49.99</span></td> </tr> <tr valign="top"> <td class="medium">$200.01 to $300.00:</td> <td class="medium"><span style="font-weight: bold;">$69.99</span></td> </tr> <tr valign="top"> <td class="medium">$300.01 to $500.00:</td> <td class="medium"><span style="font-weight: bold;">$89.99</span></td> </tr> <tr valign="top"> <td class="medium">$500.01 to $1000.00:</td> <td class="medium"><span style="font-weight: bold;">$109.99</span></td> </tr> <tr> <td class="medium">
For oversized international orders over $1000.00, customers will be billed an initial shipping deposit of $150. Once the actual shipping cost for the order is calculated at the time of shipment, any unused funds will be credited back to the customer.</p>
Customer will be notified of the final shipping costs when your order has been processed.</p>
Please be assured that Advantage Hobby will charge only the actual shipping costs as billed by USPS for these shipments.</p> </td> </tr> </tbody></table>
Old 10-12-2009 | 07:17 PM
Much appreciated W8ye
Old 11-19-2009 | 12:18 AM
Just got one today, plan on using it in a Twist or 40 size Ultra Stick. I have an older 46nt and it's just been a peach. I hope this one's as good. I was kind of hoping it would be a versatile engine for me. I think you could push it some and install it in some 60 size planes if you wanted the option.
Old 11-19-2009 | 05:30 PM
Received mine a couple of weeks back. It has very tight pinch even without a glow plug.
It looks a winner, though as always the proof of the pudding is in the eating. I have not fired it up yet.
Old 11-19-2009 | 05:34 PM
SpinnerRow's Avatar
You guys let us know how they work out. When I went to buy one, they were out at the hobby shop. Now, I'm torn between an OS 55AX or this guy. I plan to run a header and pipe on it.
