 CARF CT-114 Tutor 2.6m Build thread >
Old 05-24-2010 | 06:18 AM
  #126
Default RE: CARF CT-114 Tutor 2.6m Build thread
Dave flying the Tutor, yesterday, at Merryfield.
http://www.youtube.com/watch?v=t3K6yV0cfNg
John
Old 05-24-2010 | 09:29 PM
  #127
My Feedback: (106)
Dave, Very good. What are your surface throws set at for scale flying?? It looks like it handles very well. Hope mine will do the same!!!
Old 05-25-2010 | 01:29 AM
  #128
H
I fly around the middle stick for most stuff and the slow Derry turns you see are quite small stick movements. I have expo at 35% ail, 50% Elevator and 40% rudder. D/R percentage on Ail/Elev are both 80%. Ailerons on 20mm radius hole and elevator on 17mm.
All JR figures.
Its a very smooth aeroplane, but can be pulled very tight and "fun Fly" turns are possible, it just looks wrong!
Dave
Old 05-26-2010 | 06:17 AM
  #129
Hi Dave,
Do you have a Powerbox Evolution in your Tutor ? and when/what makes you decide to use the evolution over a Gemini, or sensor switch ???
Hope that makes sence...
Cheers Jeremy.
Old 05-26-2010 | 07:14 AM
  #130
Jeremy
No, I have a Competition in it. Only reason over the Evolution is the 7 channels (its an older version) rather than 6 channels.
I would not use a Sensor or Gemini in a large aeroplane as they are just switches, the PB units boost the signal and screen the Rx.
I have each aileron, elevator and flap on a channel and the rudder and nose steering share because no reverse is needed. That is the 7 channel on the longer leads, I then run throttle, brakes, smoke and gear + Doors directly through the RX. I don't use a sequencer I use servo slow on the DSX-12 to sequence the gear/doors. The New PB Cockpit could be used to save a channel
Dave
Old 05-26-2010 | 08:15 AM
  #131
Jeremy and other followers, there is a draft (no pictures) version of the instructions posted on the CARF site.
Dave
Old 05-26-2010 | 04:33 PM
  #132
ORIGINAL: Dave Wilshere
Dave
Hi Dave,
Yes i saw that draft, when do you expect the finished version with full pictures to be out and online ???
Cheers Jeremy.
Old 05-27-2010 | 01:26 AM
  #133
Jeremy
It's been worked on now, soon as it's finished!
Dave
Old 05-29-2010 | 11:51 AM
  #134
AKB
Thanks Dave for your info. Does anyone know if there is a lighting package for the Tutor yet. Unless you have been to one of there performances you don't know how much that big light out front is part of there show. Also what about a scale pilot, not to pick on yours Dave, but I know he is an action figure from some animation series but I don't know what. To give you a heads up there uniforms are red, that would be a good start.
Alan
Old 05-29-2010 | 02:05 PM
  #135
Alan
Nothing yet, but plenty available. My nose light is way underpowered...you can only see it in grey dark conditions!
The Pilot is a Graupner "Bust" mounted on a black cross plate, it was the only 1/4 scale pilot I had in stock...It was better than nothing. Scale 1/4 Scale full body pilots will be ordered very soon from MAF in Germany.
Dave
Old 05-29-2010 | 03:18 PM
  #136
Colin Gontier's Avatar
Airpower.eu are doing a lighting system for the Tutor. It's not cheap but I have one of their systems already and it's brilliant, super bright lights, good controller and very complete package.
Here's the link for the tutor set
http://shop.strato.de/epages/1545266...roducts/500753
Old 06-01-2010 | 04:34 AM
  #137
Ralf does it again, I asked about the extra Snowbird decals as the original and a week later....
Dw
Old 06-03-2010 | 09:54 AM
  #138
The process is about to start again, the first of the Tutor kits arrived today, this one is to be built by Steve Roberts and me for a friend...as he is loaning it to us for the Formation Cup! Thanks Simon ;-)
I noted the new scheme is on CARF's site too...
Dw
ID:	1447453   Click image for larger version
Old 06-03-2010 | 10:07 AM
  #139
Sweet!
Crack on then Davey!
Steve
Old 06-06-2010 | 01:37 PM
  #140
Another great day flying the Tutor. Last additional detail for me, I scratched in the flap and added the last decals from Ralf.
Still moving the balance point forward as I find in a wind it is slightly pitchy (possibly a tail area related thing) I think this bird likes to have the balance point in a forward position.
Dw
ID:	1448808   Click image for larger version
ID:	1448809   Click image for larger version
ID:	1448810   Click image for larger version
Old 06-06-2010 | 02:18 PM
  #141
Flying shots Dave...
ID:	1448821   Click image for larger version
ID:	1448822   Click image for larger version
ID:	1448823   Click image for larger version
ID:	1448824   Click image for larger version
ID:	1448825   Click image for larger version
ID:	1448826   Click image for larger version
ID:	1448827   Click image for larger version
Old 06-06-2010 | 02:28 PM
  #142
More
ID:	1448829   Click image for larger version
ID:	1448830   Click image for larger version
ID:	1448831   Click image for larger version
ID:	1448832   Click image for larger version
ID:	1448833   Click image for larger version
ID:	1448834   Click image for larger version
ID:	1448835   Click image for larger version
Old 07-04-2010 | 02:26 PM
  #143
Another day with the Tutor, 5 flights today, four with Steve Roberts, so he could get used to it before we fly two in the formation cup.
So far zero maintenance required after 20+ flights.
Dw
ID:	1463014   Click image for larger version
ID:	1463015   Click image for larger version
Old 07-06-2010 | 07:33 AM
  #144
Vinceyboy's Avatar
High Dave, a superb and thoroughly interesting thread, this bird has grown & grown on me since I started reading about it, it's firmly on my wish list, wish being the operative word
Hoping you will be bringing it along to the Nats for us to drool over[8D]
best regards,
Vince.
PS I'll be running the Jet line[sm=thumbs_up.gif]
Old 07-06-2010 | 01:14 PM
  #145
Vince
Will be at CJ this Friday, hopefully with it's brother!
Unlikely to take it to the Nats as the show line changes left a bad taste in the past, even with a good guy like you running it I'm now too busy with a trade stand and competing in F3c
Dave
Old 07-30-2010 | 01:48 PM
  #146
At last. My Golden Cenntenaries Tutor arrived today.
Thanks to Andy Kane for his patience with me. That thing
is huge. Will start assembly soon.
ENT
Old 07-30-2010 | 02:19 PM
  #147
ENT
Any questions on the build, please feel free to email me at [email protected], I'm not always looking at RCU since sometimes it's full of rubbish
Dave
Old 07-30-2010 | 02:29 PM
  #148
Thanks Dave. As soon as building begins I'll be contacting you.
I'll be posting some photos. Any one else with this paint scheme?
Hector ( ENT).
Old 07-31-2010 | 10:18 AM
  #149
Hi! Dave, Hector again. Who should I contact to get the Golden Centannaries
decals from?
Old 07-31-2010 | 01:19 PM
  #150
Hector
Ralf at Tailor Made Decals in Germany...he is the man.
Best Regards
Dave
