cosmos 45
Old 03-08-2010 | 12:25 AM
rv7driver's Avatar
My Feedback: (105)
Default cosmos 45
Ok, I have a framed up Cosmos 45, got it from Dan Hines (Deadstick) through a trade a while back. Its cover in fiberglass and looks to be in great shape has canopy and belly pan, no control surfaces, elevator, rudder, Ailerons does anybody have a set of plans that they could send a copy of the controls? so I can finish this bird up. Thanks ahead of time.. Regards, Pete
Old 03-08-2010 | 03:29 AM
My Feedback: (18)
Default RE: cosmos 45
Awesome Pete!!
I have a kit so I can trace the parts if you like...I believe I may also have an extra copy of the print if I didn't give it away...If I can't find it I can get another made...I need to get the Skymaster done too...
Been wanting to touch base with you anyhow so let me know when would be convenient...Really wanna check out your Atlanta!!
Take care..
Chuck
Here ie a little inspirational photo of another RCU members (Ranc68) Cosmos...
Old 03-08-2010 | 04:06 AM
rv7driver's Avatar
My Feedback: (105)
Chuck, perfect will be home on the 17th, pm me your phone #, I lost it. Ya lets get togeather and you can check out the Atlanta and thanks for the photo it does motivate me!!!!!!!!!
Regards, Pete
Old 03-08-2010 | 10:48 PM
My Feedback: (7)
It doesn't get any better than a Cosmos. What a beautiful airplane. Was that a Naruke design as well?
Greg Grigsby
Old 03-09-2010 | 04:21 PM
My Feedback: (121)
Yes. The immediate predecessor of the Aurora.
Old 03-22-2010 | 11:21 PM
doxilia's Avatar
I hope Pete won't mind me using his thread for the query. I figured it didn't warrant a separate thread.
In short, anyone here pick up the Cosmos 40 kit from Bob recently for sale? Any info on the differences similarities with the 60 version would be interesting to know.
David.
Old 03-23-2010 | 05:03 PM
My Feedback: (121)
Biggest difference is that the 40 sized Cosmos is designed for a side exhaust engine. Otherwise, just a smaller Cosmos.
Old 03-24-2010 | 05:31 PM
rv7driver's Avatar
My Feedback: (105)
Boy do I feel stupid!!, this is a comos 45 not a 60. here are some pic's. wing span 57 1/2" Pete
ID:	1404187   Click image for larger version
ID:	1404188   Click image for larger version
Old 03-24-2010 | 05:44 PM
doxilia's Avatar
Pete,
well, she looks ready for some primer! Other than that, all you need is a YS 45 FS, Hatori header and 400 pipe!
Were you able to get a copy of the plans for the control surfaces?
David.
Old 03-24-2010 | 06:09 PM
My Feedback: (18)
The Hatori header should be #552 if your running a YS 45 FS engine (which you should!!)...
http://shop.singahobby.com/?q=node/18127
Boy that thing looks really nice Pete!!
I see a nice looking scale dash leaning up against your back wall in the first shot...Oh..That may be for the .60 size plane cause it looks a little big for the .45...
Old 03-24-2010 | 06:26 PM
rv7driver's Avatar
My Feedback: (105)
Hi Chuck and David, sorry I have not called you Chuck after finding out I had a 45 I was depressed! not really. The Cosmos only has 1 coat of on it and its been on there a long time some of the fiberglass has pulled off. Chuck maybe you can look at it and give me some advice finishing it. The plane you see in the background is a sterling Piper Tri Pacer 54 WS.
I met Dan Hines down at Perry and he gave me that plane with the Cosmos that I traded him for.
Regards, Pete PS: Chuck could you call me PM sent
Old 03-24-2010 | 07:23 PM
doxilia's Avatar
By the way,
those rowing machines are actually intended to catapult launch classic pattern designs with gear up!
Pete, if the wood is sealed and there's already glass on it, I would consider using waterborne primer/paint starting with polycrylic prep followed by a mix of talk/PC to fill the weave. I don't think there's any issue with using PC atop epoxy if that's what Dan used to lay the glass down. A good sanding might be in order first though.
David.
Old 03-24-2010 | 07:24 PM
My Feedback: (18)
Aww Pete I was talking about your RV-7 dash...
Old 03-24-2010 | 08:22 PM
rv7driver's Avatar
My Feedback: (105)
Chuck, sorry, your right that is my panel for the RV7 did not see it! lol! I might try that David, just don't know if I can get my wife to row it that fast! Pete
Old 03-25-2010 | 07:05 AM
KP.
My Feedback: (77)
I have a built Cosmos 60 that I am currently flying. I need a Bellypan for it. Does any one have a kit that I can make a quick mold of the bellypan? I contacted a Hobby Shop in Hong Kong and they want $120.00 plus $30Sh for one. A little too pricy for me. I have been flying the plane for around 8 years without a pan. I will upload a pic later today of the plane.....Thanks....Ken
