Supra Fly 60 build
Old 03-24-2010, 07:46 AM
csimpson
Default Supra Fly 60 build
Well here I go... I'm gonna do it. I've obtained a set of Supra Fly 2500 plans that I scaled down to match Hanno's 60 size specs. Thanks again bem!
It will be foam core wings, stab, and turtle decks. I have an original cowl that I will try to reproduce in glass. I also have a new canopy that Will need to be reproduced. I'm not sure about that one yet. I hope that anyone who has any pics or info post it here for all to see. I'll try to post pics as I get into this project.
I've been wanting to do this for a long time and started one other time on the 45. Please wish me luck! I'll need it!!!
Chris
ID:	1403947   Click image for larger version
ID:	1403948   Click image for larger version
ID:	1403949   Click image for larger version
ID:	1403950   Click image for larger version
ID:	1403951   Click image for larger version
ID:	1403952   Click image for larger version
Old 03-24-2010, 07:47 AM
Atlanta 60
My Feedback: (18)
Default RE: Supra Fly 60 build
Good Luck!!
Old 03-24-2010, 12:54 PM
csimpson
Does anyone know the airfoil Hanno used on this? I'll probably just digitize it into cad.
Old 03-25-2010, 06:06 PM
csimpson
He's the scaled drawing, original cowl, original canopy and new OS ready to go. The fuse formers, and wing templates are digitized into cad and will be sent out for cutting tomorrow.
Old 03-25-2010, 08:42 PM
doxilia
doxilia's Avatar
Chris,
great project. Surely you've also seen Steve's 2500 build in the forum.
What are you going to use for landing gear?
David.
Old 03-25-2010, 09:27 PM
csimpson
I have seen that thread. I was originally going to build the bigger 2500 but really didn't want that big of a plane right now.
There's no way I could build this plane and not have retracts. I do plan on using new style Supra's
Old 03-26-2010, 12:33 AM
bem
Hi,
I assume You have seen that stab and wing templates on the drawing are the outer edge WITH sheeting. So You need to substract the thickness of the sheeting you are going touse so the templatesfor foam-cutting will be accurate. Just easy to forget this. Just measure on the drawing and You will see this.
It will be exciting to follow this build.
/Bo
Old 03-26-2010, 07:19 AM
csimpson
Thanks for the tip. I hadn't noticed that.
Old 03-26-2010, 03:26 PM
underwood1
good luck , what anoher great project !!....
regards
steve
Old 03-28-2010, 09:36 PM
csimpson
Here's a few pics of the cowl mold. I forgot to take a picture prior to pouring the material. I think the mold turned out very nice. It'a a 2 part polyurethane used for industrial molds.
ID:	1406833   Click image for larger version
ID:	1406834   Click image for larger version
Old 04-05-2010, 09:34 PM
csimpson
Here's a few updates... Got the gel cote in the mold, glass laid, and the first cowl out. It turned out really good for my first glass project. I'm also thinking about doing the turtle decks with glass or carbon fibre... The fuse sides are also done just waiting to get the formers finished up.
ID:	1412707   Click image for larger version
ID:	1412708   Click image for larger version
Old 04-05-2010, 10:09 PM
doxilia
doxilia's Avatar
Chris,
very nicely done!
With the cowl and canopy molds, you should consider making a short kit including these, and laser cut wood for the fuse and cores for the wings, stabs and turtle deck. Glass, carbon decks sound nice but they do require painting. Using sheeted foam decks gives you the option to produce a model which can be entirely covered (except for the cowl).
BTW, what industrial mold material did you use for the cowl? Where to obtain it? I like what appears to be a relatively easy pour into the mould container approach.
David.
P.S. I'm building a Calypso at the moment - getting retract gear work done on the panels.
Old 04-06-2010, 12:49 PM
csimpson
Thank you David, I'd like to do a kit for this but first things first. Once I get through this one I'll look more into that. I'm planning on painting the fuse so the glass or carbon deck will be quicker and easier for me right now. I'm even considering painting the entire plane.
The material I used for the mold was given to me by a friend that works in a pattern shop. It's called Pro-cast 132. It was very easy to use and didn't harm my brand new Supra-Fly 45 Unlimited cowl. I'm not sure were to get it but I bet there's a lot of other products just like it.
Old 04-08-2010, 02:22 PM
bem
Chris,
Here are some more Supra Fly 60 pictures. It is from EZ Modelers Catalog No. 5.
Maybe they will inspire You on your way to building,finish and eventually fly your Supra Fly.
regards,
Bo
ID:	1414360   Click image for larger version
ID:	1414361   Click image for larger version
ID:	1414362   Click image for larger version
ID:	1414363   Click image for larger version
Old 04-08-2010, 02:29 PM
csimpson
Bo, once again... Thank you. The info and pictures are awesome.
Old 04-18-2010, 08:14 PM
csimpson
Thought it was time for an update. There's not much to see here, fuse is coming together. Wing and stab cores should be here in a week or two.
Old 04-19-2010, 03:32 PM
doxilia
doxilia's Avatar
Double post.
Old 04-19-2010, 03:34 PM
doxilia
doxilia's Avatar
Chris,
very nice! Progress?
I'm just about 3 years behind you...
When you have some figures/info on the cowl/canopy and cores, please PM me with costs. It might also be worth looking into having the decks done in foam - precise and quick. Since one is sheeting wings/stabs, doing the decks as well as just a little more epoxy...
I did the decks with formers and sheeting but it is somewhat more time consuming if you want clean and light results (bored out all the formers).
David.
Old 04-19-2010, 06:37 PM
csimpson
What plans did you use for yours?
Old 04-19-2010, 08:18 PM
doxilia
doxilia's Avatar
The ones I haven't drawn up yet... Actually, there are no Calypso plans I'm aware of so I will draw some up.
This is a Blue Bird (World Models) kit. For what its worth, some cores, some fuse sides and some badly warped glass, ply and balsa. Considering its a ~27 year old kit, I can't complain. Back in the day it would have been something - today, better off laser cutting fresh cores and wood. I was interested in your mold material in order to make one for this cowl. Hopefully, I'll get around to it before putting it in service.
David.
Old 04-19-2010, 08:21 PM
doxilia
doxilia's Avatar
Chris,
did Bo send you the 2500 digitally? I have a copy but it is pretty poor quality so I can't blow it up.
David.
Old 04-19-2010, 09:51 PM
csimpson
ORIGINAL: doxilia
Chris,
David.
Yes, I got them in both PDF and TIF formats.
Old 04-27-2010, 07:32 PM
csimpson
Here's some updated pictures. Fuse formers, firewall, and rear pipe tunnel are in. I laminated 6oz carbon on lite-ply. I think they turned out great!
ID:	1426545   Click image for larger version
ID:	1426546   Click image for larger version
Old 04-29-2010, 10:05 PM
csimpson
I got back on reproducing the canopy.
Here's the pics.
I cradled the original, sealed it off, and used the same material that I used to mold the cowl.
Now it's time to build the vacuum form!
ID:	1428212   Click image for larger version
ID:	1428213   Click image for larger version
ID:	1428214   Click image for larger version
ID:	1428215   Click image for larger version
Old 04-29-2010, 10:24 PM
doxilia
doxilia's Avatar
This is very cool Chris.
So the ply plates on the bottom are to provide some structure to the plug? To pull the original canopy from the plug, do you simply disassemble the cradle and pull it right off? I imagine you need to spray the canopy interior with release wax - correct?
I understand that mold silicone is quite pricey but I bet it is really very fast compared to the traditional two part glass/epoxy approach - right?
David.
