MVVS 58 prosport
Old 07-25-2010 | 04:01 AM
Default MVVS 58 prosport
Hi all
did a search but not realy answered what I was after
Set up first
MVVS 58 proSport 3/4 run in
MVVS header and canister silencer
2 lipo igniton
prop currently 24/ 10 wood
My problem
cannot seem to get the engine to run anything near like it should
needles from closed turns 2.10 low 4 high!
revs down around 5500 pick up poor, good cooling in cowlbut shows signs of sagging in verticals ie under load, pick up from idle to power is slow
Questions
Silly one first is this a long pipe set up, I have the ignition set for long?
Is the prop too much
do you think there is problem with carb given the seetings. high run adjustment at full throttle on ground makes small difference
have I got an air leak somewhere
I have checked the pressure pipes and other connections and are correct
Any views
thanks Ian
Old 07-25-2010 | 06:35 AM
w8ye's Avatar
My Feedback: (16)
Default RE: MVVS 58 prosport
Too much prop
Old 07-25-2010 | 08:59 AM
Walt and Sage's Avatar
Try a VESS 23xA.. Should pull stumps...
Old 07-25-2010 | 01:43 PM
apalsson's Avatar
Hi Ian,
I tend to disagree with the two comments above. A 24x10 prop is well within the stated specs for your engine. In fact, the 24x10 is almost in the middle of the recommended props for this engine.
It sounds to me like your engine is set very rich. The MVVS manual gives some recommendations on settings, of L=1.45min and H=1.10
Try the following:
1. Set both needles to the starting point above
2. Lean out the H needle till you get maximum RPM and then richen it by around 1/8th of a turn
3. Set the engine for high-idle. Now lean out the L needle for max RPM
4. Repeat 2 and 3
I know this is not quite the procedure in the MVVS manual but it will get you to the same point
Old 07-25-2010 | 03:19 PM
Hi thanks for the input guys
I thought the prop was about ok, perhaps a little too much during running in, but close and I have been careful not to over load it in flight ie mostly 1/2 to 3/4  throttle
But I could not get it to richen up at the high end hence the needle so far out
i will go back and try using your settings which as you say are close to factory.
A club mate has the same motor but different pipe, his is a tuned pipe whereas I am using the MVVS cannister pipe, which I assumed to set the ignition to long pipe, i wondered if it is where the baffle is and may be I should be on short pipe ignititon setting?
If not I might go down in prop size and pitch to see if I can get it to rev into the 6500 range
any further views welcomed
Ian
Old 07-25-2010 | 03:30 PM
apalsson's Avatar
ORIGINAL: Ian R
snip
Ian, do you think it's possible you have a minor air leak in a fuel line, letting the engine draw air together with the petrol?
Old 07-25-2010 | 03:41 PM
I plumbed it with proper tygon and wire locked  the tube on. I will check and replace the pipe anyway incase it has a pinhole.
I fly turbines mostly so I  am alawys pretty careful on the fuel pipe side, but you never know I will replace it  all from the clunk to the carb
thanks Ian</p>
Old 07-26-2010 | 04:14 PM
prop and canister setup are OK.
The ignition should be plug and play, and needs no programming whatsoever, even on tuned pipes. If you programmed for the tuned pipe (long), you might loosen one sensor screw and retard or advance ignition a bit. One mm movement is about 3° ignition timing.
I think the carb settings are way off!
Do you use a dedicated line from clunk to carb? NO T-connections there please.
Is the carb filter clean? Check the internal strainer, and use a felt clunk.
Check the carb lever settings and internal parts. Use a carb fuel pressure tester. (may need professional help there)
Some Walbro carbs just do not perform as they should. If nothing seems to work, replace the carb!
Old 07-26-2010 | 04:30 PM
Pe
Thanks for your input
guilty as charged  I have a tee to a stopper fill valve, I  will do away with that
Felt clunk, tygon tube wire locked already
on the 58 ignition pack s std I think, I thought you could change the igntiion for normal silencer or long silencer hence why i went with the long set up
I will check the filter in carb
I have a friend who can do the pressure test
So a bit to do
24x10 wood ok for prop ie not over proped?
will let you know how I get on
thanks
Ian</p>
Old 07-26-2010 | 05:00 PM
a 24x8 is under propped.
The ignition timing should not be a big deal. Maybe 100 rpm max power or so. The weird carb tuning worries me a lot more. The engine behaviour looks like lean. It might be a leak in the T-line connection, or a clogged inner carb filter. Further investigation could include the internal carb lever height (too low), or aerodynamical forces reducing the cowl pressure in flight. These act on the regulating membrane, and can cause the carb to go lean. The prosport has a fitting on the membrane cover. Fit a line to it, and route it to a static pressure tube as used for glider variometers.
Old 07-26-2010 | 06:57 PM
Isn't prosport ignition 3 lipo not 2?
Old 07-26-2010 | 10:37 PM
Engine is way to rich turn the low side till it bottoms then backin out 1 1/2 turns do the same to the high side but back it out 2 to 2 1/2
that will get ya in the ball park.
Old 07-27-2010 | 06:23 AM
ORIGINAL: Kema
It depends:
latest engines are supplied with ICU-S ignitions. The P ignitions got thumb-downs by most users who prefer the smaller battery packs.
Old 07-30-2010 | 11:53 AM
Hi Pe
Plumbed the fuel line direct to the carb. checked the clunk replaced all tygon and re wire locked the tubes on.
tried different fresh fuel.
no difference
So I have removed the carb and will get it checked. After that new carb!
thanks Ian
Old 07-30-2010 | 12:54 PM
I suggest you try a crankcase pressure test first.
When you blow in the carb pulse line, there should be no air leaks in the front bearing area (piston halfway up), The reeds should close up fairly well. The engine pumps harder than you can blow, so with running engine they will close completely.
Old 07-31-2010 | 03:40 AM
hi Pe
Tried the crankcase pressure test
I have the carb off when I did it
It would appear that air is passing through the reed valve through most of the rotation of the engine
I tried it half way it passed air and so slowly turned through full rev either side of top dead centre and it seemed to leak air at the same amount
Ian
Old 07-31-2010 | 04:34 AM
Like I said in the previous post, some reed leakage is normal. You can check the cage if you want, and will see that the reeds are about 0.5mm open. They will lie flat as soon as any decent pressure works against them. like in a running engine. So if you check them, look for frayed or broken reeds, or reeds that are excessively open. Also look for reeds that are tightened to the cage too much. This will cause reed deformation.
How was the rest of the engine?
</p>
Old 07-31-2010 | 03:00 PM
hi Pe
Reeds look ok, nothing from the front bearing as far as can tell
rest of engine appears ok good compression etc
will invstigate carb tomorrow
thanks  for help
ian
Old 08-01-2010 | 04:38 AM
Hi Pe
Checked carb by removing the top and botom covers. all looks like the they should do, ie no out of position or visible damage
gauze looks clear. So only thing left is pressure test.
Ian
Old 08-01-2010 | 04:40 PM
While checking, also check the muffler and header for restrictions, just to be sure the engine is not choked.
When does the ignition fire? It should spark just before the piston reaches top dead center. (0.1mm before top dead center would be about OK)</p>
Old 08-02-2010 | 01:55 PM
Hi Pe
Carb pressure test ok.
Your question about the exhaust made me think
I had to make a maifold for the engine to mvvs silencer for the model I am using it in , the standard MVVS would not come close for alignment
I attach the photos of mine
I did smooth the gas flow in my version so itis not the angled face theoutside would lead you toconcluded,but even so I can now see that there could be a back pressure into the cylinder. do you think this is the cause given we have tried everythink else!
Ian
ID:	1477058   Click image for larger version
ID:	1477059   Click image for larger version
Old 08-02-2010 | 02:26 PM
Normally, an engine can handle some exhaust restriction because of the high exhaust gas pressures.
I am not sure what you did, but the 45° angle the header leaves in the picture reduces the exhaust area by about 30%, and that may well restrict exhaust flow in the high rpm regions. A larger prop therefore might do a lot better than your medium range 24x10 which needs to rev up.
Test the engine on a test stand with a more open header, and you will know. All else on your rig seems to be OK.
Old 08-02-2010 | 02:34 PM
Ok will try the test stand
 thanks for your continued help
Ian
Old 08-11-2010 | 02:44 PM
Hi Pe
Sorry for delay, well what can I say!
engine bolted to test stand  with my manifold and the MVVS canister pipe, ignition unit from model, did not put the  vent pipe on static pressure side of of carb. connected crankcase pipe to carb. same prop same fuel.
Did it run yes and pretty good.
Ok so back in model as is, surprise same problems as before would not run at high RPM.[:@]
I did notice it would pick up when cold but as soon as warmed up it would sag. I wonder if it is just the manifold or do you think the canister is getting too hot. when I bench tested it was very hot in the open I can imagine inside the model in a tunnel opended front and rear it  would still get even hotter.
I am wondering if  to get a standard can exhaust and give that a try ie no header and no canister
What do you think?
I am on the point of sending  it []back to mvvs
Ian
Old 08-11-2010 | 04:49 PM
why send it back to MVVS when it runs good? It is the setup in your model that is causing the problem, not the engine itself.
Engines often do run different when in the model. You have to tune the needles again, due to vibrations and/or changes in carb membrane reference pressure.
Header the same? Same length? If it runs hotter in the model, your header needs to be longer to compensate. Add about two inches to the header length and start from there.
