MarketPlace questions or problem? Post questions or problems related to the RC Universe Marketplace in this forum.
help
Old 10-14-2002 | 06:27 PM
evan-RCU's Avatar
Default help
I don't have a photo program, could I send a picture to some one and they make it small enough for an avitar?
Old 10-14-2002 | 07:28 PM
My Feedback: (8)
Default help
You can use paint to size it down. Just select all and move it down till it reaches 85X85, or smaller.
Old 10-14-2002 | 07:45 PM
evan-RCU's Avatar
Default help
and then save it? it seems that it save the white around it when I do???
Old 10-14-2002 | 08:00 PM
My Feedback: (8)
Default help
After you resize it you have to resize the white part, too. Put your cursoron the bottom right hand edge of the white part, on the small blue square, and click and hold to resize it to the same size as your picture. Resize it till there is no more white left. Sometimes you do it and get a little white around the edge, if you resize one more click than you think you have to then that will fix it. Then save it as a jpeg or a gif. I recomend a jpeg if you have a lot of color in it.
Old 10-15-2002 | 12:20 PM
evan-RCU's Avatar
Default help
that was a lot harder to do than it should have been
Old 10-15-2002 | 12:24 PM
evan-RCU's Avatar
Default help
try again
Old 10-15-2002 | 12:25 PM
evan-RCU's Avatar
Default help
Its too small and when I make it bigger it stayed the same???
