Go Back  RCU Forums > RC Universe Support > MarketPlace questions or problem?
 Breaking down adds by distance! >
MarketPlace questions or problem? Post questions or problems related to the RC Universe Marketplace in this forum.
Old 09-04-2005 | 09:58 PM
Default Breaking down adds by distance!
Hi;Not sure if I put this correct!What I am wondering is if it would be possible to look at adds only within so many miles of me!What I am thinking of is on Ebay I can specifiy adds within so many miles of my location!The cost of shipping planes and possible damage etc is so high no use drooling over something with a $100 shipping bill there I can look at things within an area I could drive to etc.Maybe this is possible now but if so I don't know how!Thanks!
Old 09-04-2005 | 10:07 PM
Default RE: Breaking down adds by distance!
Hi!Sorry about the Duplication!!Pushed to many buttons!
Old 09-04-2005 | 11:49 PM
JWN's Avatar
JWN
Community Moderators
My Feedback: (42)
You can do a search in the Advanced Search tool to display only those ads within a anything from 50-1000 miles of your zip code.
Old 09-05-2005 | 09:15 PM
Hi;Thanks for the info!!Will go try it out now.Suprising what you can find out if you just ask!Thanks!!
Old 09-05-2005 | 09:50 PM
Hi again!What I wanted to do would be to set a default?at 200miles that would remain.Now on advance searchI can go to airplanes then adv search and set the 200 but I get everything cars etc to even though I specify Airplanes and it is gone if I try to go to another item,Engine etc.I tried to specify farther down it says something about use ctrl and shift but this again doesn't allow the set 2 things airplanes and motor etc all of area goes dark if you do this covers all items in that block?Guess maybe not making myself clear hard to explain.Thanks anyway!
Old 09-05-2005 | 11:20 PM
JWN's Avatar
JWN
My Feedback: (42)
There currently is not a way to set at default listing radius, but this is a good suggestion.
To select more than one category, but not all, hold down the Ctrl key and click on those categories you wish to search. If you click cars on accident, keeping holding the Ctrl key and click on cars again to deselect it. You would use Shift if you wanted to select multiple categories, but did not want to click on everyone one of the. For instance, if you want to browse airplanes, boats, cars and engines. Click on airplanes, press and hold the shift key then click on engines. Everything between engines and airplanes is selected in one go. If you wanted to exclude cars after doing this, press the Ctrl key and click on cars to deselect it, then perform your search.
Old 09-06-2005 | 08:12 AM
Hi;Thanks for the assistance,did figure out that only hit the cntrl key for each I was hitting both keys which gave all the items in that box.Guess you did answer my original thought to set a permanet default to the distance then I could go to any area without having to go to the settings and set it each time.Apparently now can only do airplanes as a whole can't look at biplanes only seperately.Again thanks for clarifying this for me!!
