New 989
OH
New 989
I have a question about the 989. I have a eflite 2/3 cell lipo charger and it requires the use of a 11.5-15 volt power supply. I wanted to know if there was a way use the power supply feature. i tried to but I couldnt get it to work. The voltage would jump around and it would just click off. I hooked the eflite charger to the main power supply without the super brain and it works fine? anyone know
NJ
RE: New 989
Sorry or the delay in my reply, still trying to get caught up from being out for a week. The power supply mode is looking for a constant power draw, like a motor. And you have to sort of match the amps and the volts to get it to work properly. Trying to use the power supply mode to power another charger won't work. You can use the included power supply with no problem, as you have found. PM with your address.
Tim
Tim
