MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
comparing glow to gas
Old 08-28-2006 | 01:21 PM
Default comparing glow to gas
the 26 cc. gas with tuned pipe can not reach 7000 ( 6900)rpm with apc 17/12;the glow version of these engine is declared in a threath in the pattern section to make 7900 with the same propeller and pipe. 1000 rpm difference means a lot of power, can these explained only by the difference in fuel?
Old 09-12-2006 | 10:41 AM
Default RE: comparing glow to gas
Dar no replay at all?
Old 09-12-2006 | 11:16 AM
Rocketman_'s Avatar
My MVVS 26 cc gas with tuned pipe reaches 8740-8800 rpm with an APC 18x6 wide prop.
I'm using it on an 11.5 pound 3D plane that hovers easily and has unlimited vertical performance.
Maybe you can make some kind of comparison to that.
Old 09-13-2006 | 10:53 AM
mine with 3266 pipe and meijnik 16/12 makes 8250 but if you compare any 26 cc glow you will see that ,with tuned pipe can spin one inch more in diameter at about the same rpm, it is only a matter of fuel?
Old 10-01-2006 | 09:18 PM
My Feedback: (7)
Rocketman
What do you think about the engine and the giant U can do 3d combination?
Yes, my plane is good 2 pounds heavier,but you mention unlimited vertical in your case(another words power to spare).
Did someone try that already?
