MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
New Ignition Syste MVVS 26
Old 04-27-2007 | 12:36 PM
Meesh's Avatar
My Feedback: (135)
Default New Ignition Syste MVVS 26
Pe, Dar,
I just bought a new MVVS 26 and noticed that they stopped using the Vlach Ignitions. The new engine has an ignition marked MSR Engines.
I have one MVVS 26 with the Vlach ignition and was planning to use both engines in a Twin.
Will the new ignition cause the engine to perform differently than the Vlach?
Will I have problems synchronizing them?
Thank You!
Bob
Old 04-27-2007 | 05:16 PM
Default RE: New Ignition Syste MVVS 26
Hardly,
Both ignitions have advance curves. In my humble opinion, the carb adjustments have greater influence on midrange than the rpm advance curve.
Old 04-29-2007 | 02:51 PM
My Feedback: (13)
Meesch & pe revers:
Even with the blury pics, have never been able to get my vlach ignition on the 26 hooked up correctly. I just leave the line to the servo off and it runs fine. I dont try to hand start the thing, good old go cart starter does fine. Mine is in a QQ 73" yak 54, flys ok other than torque rolls. Lets see, last time I flew the thins was about 8 months ago. Should get around to getting it hooked up right, but the lingth of plug wire forced the box location inside the fuse. Not anxious to dig it out.
I have the BCM muffler that runs vertically down, choisen at the time as there was nothing that would obviously work with the qq yak motor mount style. Is there a better performing muffler out there that will work with this install you are aware of? Thanks.
Old 04-29-2007 | 04:25 PM
You won't miss the choke servo. It's a nice gadget, but no necessity.
edit:
BTW, you have a MSR ignition AKA ICU. This is the latest one, and if you have a 26cc engine, there won't be a choke servo connection to hook up. The 26 and 35cc have the light version which don't have the choke option.
