one battery system possible
can i use one battery to supply power to ignition and reciever say a 3400 mha 5 cell pack to save weight has anyone used this set up
Negy,
Imagine what would happen if the battery is drained by the ignition system....
If a separate on-board radio battery still has some juice in it, you could make a dead-stick landing, but if it is the same battery???
I would strongly advise against it.
Even electric power models that do use a single power source, have a BEC that reduces, or cuts off engine power, but retains control of the model...
Friend,
I do not recommend you. You can have prolem with interferencies and You have to be sure you have electr. energy for reciever for safe landing.
Must be curful
Jan
Must be curful
Jan
what about a limiting switch where by the power on the ignignition side is reduced or stoped would be a good option or a indication of lack of remaining power so a to at least do a dead stick landing
